Old 03-06-2012, 10:50 PM   #1
Johannes
Johannes's Avatar
Johannes is an unknown quantity at this point
Fidanza Aluminum Flywheel Re-Tap to bigger bolts
Heya. I got a question about my Fidanza flywheel, I was torquing four bolts in different places but they got stripped, so I tried re-tapping them with the same thread size/pitch but it just stripped again cause of the material being aluminum.
I re-tapped four of the holes with a bigger tap, and bolts and I just honed the clutch holes to work with the bigger bolts that I'm using. I also used blue thread locker on the bolts.
The weight of the bigger bolts are about half as heavy as the old ones.
Onto my question, I was wondering if this would affect the clutch/flywheels' balance and if it would affect it in such a way that will lead to failure?
Open to inputs/suggestions. Thanks!
& Here's what I'm talking about:
Johannes is offline   Reply With Quote
Old 03-06-2012, 11:15 PM   #2
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
yes it will. you should drill out the rest of them so that it will be balanced.
rcdad123 is offline   Reply With Quote
Old 03-07-2012, 12:35 AM   #3
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
I second that, you want everything as balanced as possible.
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 03-07-2012, 03:09 AM   #4
59bhp
59bhp is an unknown quantity at this point
you could of helicoiled them so that you could use the original bolts, just for future reference
59bhp is offline   Reply With Quote
