Old 03-09-2012, 03:47 AM   #1
ardeine
ardeine is an unknown quantity at this point
does anyone know where this plug suppose to go? s14 maf sensor
so im trying to figure out if this is causing my car to keep dying on me. does anyone know where this plug is suppose to go?
much help appreciated!
ardeine is offline   Reply With Quote
Old 03-09-2012, 01:13 PM   #2
Dorifto Machine
Dorifto Machine's Avatar
Dorifto Machine is a well-known jackass
No that is not your problem, that is a secondary sensor for your stock airbox/intake system. When you have a aftermarket intake air filter, that will no longer be plugged into anything.
Check for Vacuum leaks around the engine.
Dorifto Machine is offline   Reply With Quote
Old 03-09-2012, 06:09 PM   #3
Sileighty_85
Sileighty_85's Avatar
Thats the Ambient Air Temp Sensor. Not sure how it affects the engine since i never really delt with a S14 KA but I know most ppl still use and and just let it dangle in the engine bay or zipe tie it some where.
Pull codes from ECU
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-12-2012, 12:44 AM   #4
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
Intake Air Temperature Sensor. It shouldn't be causing your engine to shut down because it doesn't really do much. I drove without one for a while.
DennisC is offline   Reply With Quote
Old 03-12-2012, 03:39 AM   #5
ardeine
i also got a iacv code popping up. what can i do to fix that problem?
Old 03-12-2012, 11:27 AM   #6
drftrkidd
drftrkidd is an unknown quantity at this point
clean your iacv or replace it the only things that you can do to fix it. probably too much carbon on your iacv
drftrkidd is offline   Reply With Quote
