Old 03-15-2012, 09:02 AM   #1
BoostWanted
BoostWanted is an unknown quantity at this point
Weird Idle,and didnt pass smog. help?
When i start my car it idles at bout 1100 then drops down to about 800. And when I sit there with it idling sometimes it makes like a puffing sound and you can feel the car shake.
Onto my smog, I failed the hc by about 20 and my no by about 300. Maybe I have a vacuum leak? How do i check? Sorry for not exact numbers. I dony have my smog paper right now.
Also another thing is when I'm driving and I put the car in neutral to coast to a light or something it stays at about 1100rpm until I come to a complete stop.
BoostWanted is offline   Reply With Quote
Old 03-15-2012, 09:32 AM   #2
Edwin562
Edwin562's Avatar
Sounds like a vacuum leak. let your car on for a bit (at idle), spray some carb clean on possbile vacuum leak areas. if idle changes then yes you have a vacuum leak.
Old 03-15-2012, 09:35 AM   #3
BoostWanted
Would that fix smog too?
Old 03-15-2012, 09:45 AM   #4
Edwin562
Edwin562's Avatar
No, that will help you find the vacuum leak if you have one. High HC(Hydrocarbon) mostly indicates your burning too much fuel or oil.
Old 03-15-2012, 09:46 AM   #5
BoostWanted
How can I fix that? I ran 91 with denaturated alcohol for the smog.
Old 03-15-2012, 09:54 AM   #6
Edwin562
Edwin562's Avatar
Post info on your car.
Old 03-15-2012, 09:56 AM   #7
BoostWanted
its a 95 S14. Has like 235k on the chassis and the last owner said the rebuilt engine has 90k on it. Uhh.. what else do you want to know? 5 speed..
