S14 Parts :: Mostly OEM
I have tons of parts for sale from my '95 240. Most of these are OEM and some are aftermarket. Please see the pictures for the items. All prices are OBO
A couple of notes: Xcessive Intake Manifold comes with Q45 MAF and KA Throttle Cable bracket. It was mounted and started once. Decided to remove it and put OEM manifold back on due to tuning issues I was experiencing. Can't really see in the pics, but I have the S14 front bumbper support brace for sale. I have the complete S14 Seatbelts; however, the driverside is frayed. I was told the Catalytic converter is gutted The exhaust manifold still have the EGR attached One of the Steering racks has a leak. It would need to be rebuilt. I have a second one that I was told was good. Aftermarket exhaust is the M2 Rear bumper is bent in a little at the flange (passenger side) Also have the MRT Exhaust for the 2005+ Ford Mustang and Pacesetter exhaust for VW Jetta (86-??? model) One of the tires has a slight leak. The wheels are 4-Lug pattern Power window amp may not work Fan shroud is broke so I will probably just throw it away. Radiator was good when removed, I swapped out for an aftermarked one with dual fans Oil pan was fine when removed. I bought one with a bung already welded on. Does not come with drain plug Downpipe is ISIS SR20 SS one. It has the AEM No-Weld 02 Bung. The gasket for the No-Weld should be replaced. Have 4 full sets of injectors for sale: KA stock, SR20 stock, 660 CC (forget brand), and ID1000's, The 660's and ID1000's were never used. Complete airbag system available. Harness has been de-pinned. Steering wheel and passenger air bag not pictured. Power Steering Pump is sold as is, not sure if it works or not Feel free to ask any questions, make any offers, and request any parts. I may have it available. All pics can be found here: Index of /sale-items Edit: Item List: Oil Pan - $60 shipped S14 Steering Rack (2 Available) - $75 Shipped for one that leaks, $125 shipped for good one M2 Cat-Back Exhaust - $40 - Local Pickup Only Gutted Catalytic Converter - $50 Shipped S14 OEM Wheels / Tires - $75 - Local Pickup Only OEM Rear Bumper - $50 - Local Pickup Only ISIS SR20 Downpipe w./ AEM No Weld O2 Bung - $75 Shipped Xcessive KA24DE Intake Manifold w./ KA Throttle Cable Bracket & Q45 Throttle Body - $450 Shipped 3rd Brake Light - $30 Shipped Headlights - Sold Corner Lights - Sold Passenger Side Markers - $15 Shipped OEM Radiator - $65 Shipped OEM Cooling Fan - $50 Shipped OEM Engine Fan - $50 Shipped (4) KA24DE Injector Clips (1 has less than 1 inch of wire) - $7.00 Shipped S14 Seat Belts (Front & Rear) :: Driver's side is frayed - $125 Shipped for all Windshield Washer Reservoir - $30 Shipped Coolant Overflow Reservoir - $30 Shipped USDM Manual Climate Control - $40 Shipped Misc Empty Blank Covers for Switch Panels (Cruise Control, Security, etc) - $5 Shipped Each Soundstream DTR4.500 Amplifier - $75 Shipped Complete Airbag system (Harness is depinned) - $100 - Local Pickup Only Several S14 DCC Sensors - $15 Shipped per Sensor S13 Dash Harness - $30 Shipped Generic Coolant Overflow Tank - $10 Shipped Stock KA24DE Injectors - $45 Shipped Stock SR20 Injectors - Sold Precision 687cc Top Feed Injectors - $200 Shipped Injector Dynamics ID1000 Top Feed Injectors - $350 Shipped OEM Fuel Pump - $50 Shipped OEM Fuel Filter - $20 Shipped Misc 6.5" Speakers - $15 Shipped Each Air Filters - $14 Shipped Each Aftermarket KA24DE Intake - $35 Shipped Stock Air Box (Behind Bumper) - Sold Hazards & Rear Defogger Buttons - $25 Shipped Each Power Steering Lines - $60 Shipped for the set Stock KA24DE MAF - $40 Shipped Stock Motor Mount Brackets - $50 Shipped Stock Power Steering Pump (Unsure if it works) - $25 Shipped Apexi SR20 Intake Pipe - $60 Shipped KA24DE Stock Downpipe - $80 Shipped Stock Exhaust Manifold with EGR Attached - $35, Local Pickup Only Stock 3 Piece Taillight set - $75 Shipped Misc Silicon Couplers - $5 Shipped Each Exhaust Manifold Heatshield - $15 Shipped S14 Front Bumper Support - $50, Local Pickup Only 95 Drivers Side Window Switch - Sold Power Window Amp - Sold DSM Shift Knob - $15 Shipped Stock Shifter - $35 Shipped Stock Shift Knob - $15 Shipped Stock Zenki Grille - $35 Shipped (2) Crossovers for speakers / tweeters - $30 Shipped Stock Shifter bezel (Boot needs replaced, no broken tabs on bezel) - $15 Shipped TVG Logo Valve stem caps - $10 Shipped Shine Auto Project Rear Valances - $75 Shipped
![]() Last edited by mdlesk; 04-20-2012 at 02:59 PM.. |
Yes, I have the OEM headlights, corners, side markers, and should also have the turn signals. All are USDM. The headlights are a little yellowish and need cleaned. See the pics link in the first post. There are some pics of the lights and bulbs.
![]() Join Date: Apr 2011
I have a 40m/bit connection and those pictures take a while to load. Holy GIANT pictures.
I am interested in a few items. I'll pop you a PM after I look at everything. With the size of those pics, It might be a while. |
#6 | |
I have added a resized folder: Index of /sale-items/resized Pics in this folder should be quite smaller and load a lot quicker.
I only have the drivers side, not sure if it works, seems like the auto-stop is broke as it just moves freely. I can do $20 shipped for it. I also have the power window amp that I will throw in for another $10.
I need both headlights, the drivers corner light, turn signal and side marker, how much shipped to 91001?
#22 |
First post updated with prices. Please make some offers, need this stuff gone soon. I also tested the power window switch and it works, just missing the spring for the auto-up.
#23 |
Hello,
I am interested in an egr tube for a ka24e as well as an intake boot if you have one. (between crossover tube and manifold) thanks I have paypal ready for price shipped to 93103 |
#25 |
I don't have any parts for the KA-E; however, I do have quite a few Silicon Couplers. Do you know the inlet and outlet size that you need?
I don't have any m/t ecu or trans wiring available. I do have an auto ecu available. I will update the first post with it in a few hours along with the Part Number
