Old 04-29-2004, 11:01 PM   #1
nismospec
nismospec is an unknown quantity at this point
which camber plates with AGXs?
i have some AGXs with sportlines on my s13 and wanted to get some camber plates, i dont know which ones will work with my AGXs.
nismospec is offline   Reply With Quote
Old 04-29-2004, 11:17 PM   #2
sxse240
sxse240 is on a distinguished road
Ignore this post and read the posts below from people smarter than me.
Original post:
None. Look at the size of the upper spring seat and then look at the size of any camber plate for coilover use. No worky.
Edit: Of course, I may be wrong. See below.
sxse240 is offline   Reply With Quote
Old 04-29-2004, 11:22 PM   #3
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
I've seen several people use tein's with AGX, so I'd have to assume the above poster is incorrect.
but feel free to check it out yourself...
andrave is offline   Reply With Quote
Old 04-29-2004, 11:46 PM   #4
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
I believe Ground Control carries some that work with AGX, I was looking at them a couple years back
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 04-30-2004, 12:12 AM   #5
knightrider
knightrider's Avatar
knightrider is an unknown quantity at this point
i have agx, and i have cusco camber plates. so sxse240, your wrong, sorry to burst your bubble. you just need to use the spacer that comes supplied with the camber plates, also, with camber plates, the front of your car is going to be lower due to the fact that they are shorter than the stock upper strut mounts, and i believe that any camber plate would work. you just need the spacer, im not sure if all camber plates include this, but my cusco camber plates did,
Drift_ Into A Mountain
Jim Wolf Technology
Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu
knightrider is offline   Reply With Quote
Old 04-30-2004, 12:29 AM   #6
nismospec
do u have the camber plates all around or just up front?
Old 04-30-2004, 12:55 AM   #7
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
there's no such thing as rear camber plates for our cars. you need adjustable control arms or camber bolts/bushings.
so the camber plates replace something on the shocks? i thought they sat between the shock mount and the shock tower. that's good to know, i'm fine with my car being a bit lower, just not a bit higher. forgive me if i don't know exactly how the shock is set up, i got my shocks and springs used so everything was already together.
cdlong is offline   Reply With Quote
Old 04-30-2004, 01:09 AM   #8
knightrider
the camber plates replace the upper strut mount, our cars dont use shocks in the front, they are struts, and yes they replace the part that bolts to the strut towers. the part that spins on the top of the strut,
Jim Wolf Technology
Old 04-30-2004, 08:14 AM   #9
sxse240
Okay, looks like I may be wrong. I had considered doing the same thing when I got a set of 18x9s (-25) that wouldn't tuck under the front. I researched it and came up with the "no worky" answer.
If someone has this setup (normal diameter springs in front with camber plates), please post up. I'd like to see how to do this.
Old 04-30-2004, 08:34 AM   #10
nismospec
knightrider do u have any pics
Old 04-30-2004, 08:51 AM   #11
orion::S14
orion::S14's Avatar
Tein camber plates will work with stock-type struts IIRC...
Buy 'em, use the included spacer, and voila! - Camber adjustment. It's a "remove and replace" deal...
- Brian
Old 04-30-2004, 09:12 AM   #12
s0ldats
s0ldats is on the path to ruins0ldats is on the path to ruin
people need to stop talking out of their asses and giving wrong information. anyway, cusco plates, tein, and t3 plates with regular spring/shock combos. there are probably more, but those are the ones that i've seen in action.
s0ldats is offline   Reply With Quote
Old 04-30-2004, 09:29 AM   #13
kandyflip445
kandyflip445's Avatar
Ok. So I can't find any stores that list them? Is this one of those parts you'd have to call/e-mail and have ordered? Also, If you do, would you have to specify that you need the spacers or would they come with them?
My 240 vBgarage
Old 04-30-2004, 10:26 AM   #14
andrave
andrave's Avatar
if you bought them new they should come with them. used...
crap shoot bordering on no.
however, I remember that there were just a set of rsr Race springs with kyb agx and tein camber plates for sale so you might be able to find them in the for sale section. they sold, but I think there were pics.
Old 04-30-2004, 12:29 PM   #15
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
Tru dat ...and btw...you can get aftermarket rear upper mounts but they aren't adjustable (because even if they were, they wouldn't do anything).
For sure, Cusco mounts work with AGX cuz I'm on them. JIC mounts are the only funky ones I've seen because they are supposedly made specifically for their struts.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 04-30-2004, 01:56 PM   #16
knightrider
no i dont have any pics, dont really have access to a camera either, but trust me it works, and the rear upper strut mounts only replace the stock rubber bushing with solid pillowballs, no adjustments in tha rear, for rear camber adjustment, ya gotta pick up adjustable rear upper control arms. and camber plates shouldnt be anything special order, but i dont know who carries them.
Jim Wolf Technology
Old 04-30-2004, 02:36 PM   #17
PSI240SX
PSI240SX is an unknown quantity at this point
HKS ones work... I just sold my RSR/AGX/HKS combo.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
Old 04-30-2004, 07:59 PM   #18
andrave
andrave's Avatar
jspec has cusco ones on their site now under newshipment , says "for strut use," 160 is steep tho.
Old 04-30-2004, 09:54 PM   #19
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
FYI, the T3 plates dont work with stock-type struts. A buddy of mine here tried them with his koni/whiteline setup and they did not come with a spacer to make them work. He has Teins now and is happy with them.
T3 would work IF they had a spacer though, unfortunately, they didnt make the spacers at the time. I havent checked back on them though, so they might have started making them now.
Chernobyl is offline   Reply With Quote
Old 05-01-2004, 01:05 AM   #20
TokyoNights
TokyoNights's Avatar
TokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really nice
Send a message via AIM to TokyoNights
Yea the t3 ones dont work..I just ordered the tein plates last week,,enjuku can get them for you.
TokyoNights is offline   Reply With Quote
Old 05-01-2004, 10:04 AM   #21
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
project silvia has the tein plates for 144
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 05-14-2004, 01:43 PM   #22
smellslikecurry
smellslikecurry's Avatar
Trader Rating: (33)
smellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfection
Feedback Score: 33 reviews
does anyone know where i can get a cusco camber plate spacer?
smellslikecurry is offline   Reply With Quote
Old 05-14-2004, 01:55 PM   #23
knightrider
ummm, did you try cusco? j/k um i dunno, i would say try a cusco dealer, maybe they can get you a couple. other than that, make your own, the spacer is jus a 15mm aluminum spacer iirc.
Jim Wolf Technology
