#2341 |
![]() Join Date: Sep 2007
i can attest to the fact that r888's suck on the street. if it isnt a very warm day and you arnt going for a long drive you may want to be pretty careful or do some hard braking to get them hot.
2004 Nissan 350z 2002 Nissan Silvia |
#2342 |
![]() Join Date: Apr 2010
I daily on r888's and they are fine as long as your not driving like a jackass. There only sketchy on standing still water but any summer/track tire is going to be a little more challenging in the rain.
#2344 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
^There Awesome
(Only exp. on the Front)
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
#2345 |
![]() Join Date: Jan 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
OKAY...so i see everyone running 275-315 tires but most are running either an unknow camber or -2 to -3 degrees. I would rather run a 255 with -.7 camber than 275 with -3 camber, am i wrong in saying that?
#2346 |
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
^ I'm actually running 275 drag radials with .5 camber
Regards, Robert
![]() 940-683-8282 x20 Robert Del Angel CLICK HERE FOR OUR FACEBOOK PAGE!!! FOLLOW US ON TWITTER!!! Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!! |
#2347 |
![]() Join Date: Nov 2009
You're probably wrong because you're thinking that's bad for you. Our cars and most other mcpherson strut cars like more negative camber (eg; bmws). It helps your turn in and grip in corners but it depends on various factors such as tyre type (not all react the same) and suspension setup.
#2348 |
![]() Join Date: Jul 2008
Trader Rating: (32)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 32 reviews
you're absolutely right. camber defeats the whole purpose of the bigger tire contact patch. for example a 255 drag radial with -.5 camber will have a greater and more usable contact patch than a 275 with -3 camber.
#2351 |
![]() Join Date: Apr 2004
Take a corner and you'll need negative camber.
I run -3.4 deg up front with my roll center corrected which gives better camber gain and I still wear the outside of the fronts on track. I'm thinking going to closer to -4 deg.
#2352 |
^I ran even -4.5 at one point.... and my tires according to my alignment guy (who races) said are unbelivabley well properly worn (with barely any wear) and i drive hard...
Toe = the devil... but camber will not chew your tires away.... In the rear too much camber may cause acceleration problems... but.. for cornering.... more neg camber in the front rocks |
#2353 | |
![]() Join Date: Nov 2007
I would think you would want less camber with less roll so the tire achieves max grip all the time....rather than max grip at -4 degrees? Unless you are running specific heavy banked tracks? Sorry man...i do the drifting, always interested in the grip dudes stuff. |
#2354 |
drifting = you're doing it wrong
lol sorry had to throw that one out :P Just kidding. Negative camber is pretty common while cornering... theres alot of forces.... we don't wana slide... we wana corner faster... |
#2355 | |
fixed ;D ![]() I've just known dudes that ran 1.8 degrees up front...but never heard of -4 on a grip car that wasn't nascar. |
#2357 |
![]() Join Date: Apr 2007
I had the opportunity to drive behind my car on (in my other car) on the way home from the track one day. Back then it had ~-0.5* on the rear (measured with a carpenter's square ,some simple math and a garage floor that is probably not flat) and it gained a notable amount of negative camber over bumps.
I know it has to do with ride height, as camber gain in increased as suspension compresses. There was about 1.5" from the top of the fender arch to my 17" wheel. And I had 10k springs on the rear. I used it like that for 2 open track days before the turbo was installed, running 225 street crap tires. I didn't feel like it was low on rear grip, but instead it pushed like normal. I don't drag race, but If I did (I would get a Mustang or Camaro ![]() I run 0* on the rear now, and I've gained some traction while sliding, but it also feels like there's less normal grip back there for normal cornering. Long, boring post. Don't read it.
#2358 |
![]() Join Date: Mar 2011
![]() ![]() ![]() Feedback Score: 7 reviews
my housemate got a new set of 17x10 Stern Reps and 295/35/17 Kumho XSs for his mk3:
![]() for shits and giggles, i tried them on my s13: ![]() ![]() ![]() ![]() ![]() ![]() ![]() specs: s13-specific PJ Bonifacio (or very similarly styled) flares, you can buy these/similar ones here f: 17x10 +20, 295/35/17, 6mm spacer r: 17x10 +20, 295/35/17 -1˚ (ish) camber all around rear clearance is fine. front is close to hitting everything when steering, even with my beat-out-to-all-hell wheel wells for steering clearance on my usual setup. if i raised it up some, i might be able to get away with it, especially if stay away from full lock. looks do-able for a track setup. drifting, not so much, it would eat shit up at full lock. also, i checked steering clearance while sitting; i didn't actually drive it. i can't promise that 6mm spacer is enough to actually clear the tire and coilover. it was REALLY close. the tire may have been resting on it, i just couldn't see back there well enough to tell for sure. i have an SR with 550cc/n62/gt2560rs/15psi, definitely no more than 300hp. i don't actually need a 295; a good compound 255 would be fine... but the insane amounts of meat is SO very tempting! ![]()
#2362 | |
Silver SC Style Wheel 94-04 Mustang (17x10) at AmericanMuscle.com - Free Shipping! ^ that
#2363 |
Hoosier a6 tires are designed to run at 3-5 degrees of camber. Anything less and you're leaving speed on the table. The best finishing S-chassis car that I know of in the scca was running 4 degrees in the front.
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#2364 | |
the nascar thing was a joke. i only know they run heavy negative camber on one side..how much...well I don't run nascar, nor do I see myself ever running nascar. Thanks for the lesson obi wan. |
#2367 |
#2370 | |
295 is an 11.6 inch tire..... just to put in perspective.... |
