Old 04-02-2012, 06:41 PM   #1
heyitzalan
heyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant future
i'm confused with rocker arms!!! with tomei solid lifters
According to this write-up, it says that the rocker arms need to be cut in order to shim correctly in conjunction with the tomei solid lifters and the valves? Can someone verify that this is correct. I bought the solid lifter and i lost the installation manual.
"You need to get your rocker arm cut like shown as recommended by Tomei. The following is actually copied from Tomei’s manual. I think this is necessary because the solid lifter is higher than your normal HLA so when the cam lobe pushes on the rocker arm, the tip might dig into the shim. Also more chance of this happening with high lift cams."
How to Build a 9000-rpm Head for your SR20DET
heyitzalan is offline   Reply With Quote
Old 04-02-2012, 06:44 PM   #2
DoobieS13
DoobieS13's Avatar
DoobieS13 is an unknown quantity at this point
http://zilvia.net/f/engine-tech/
DoobieS13 is offline   Reply With Quote
Old 04-02-2012, 08:41 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Yes, you have to mod the rocker arms. Follow the recommendations from Tomei, can't remember what the angle is since its been so long since i had mine done.
CLICK HERE!!!
Old 04-02-2012, 08:46 PM   #4
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
I love how Tomei solid lifters are 1/4 the price of bnib oem hydraulic lifters. Shit trips me out since tomei stuff is usually an arm and a leg lol.
Follow Tomeis recommendations. They know best.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
