Old 04-29-2012, 05:11 PM   #1
8Nismo9
8Nismo9's Avatar
8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough
Send a message via AIM to 8Nismo9
s14 Ka24de high idle help
My 96 s14 with a 5 speed swap idles at 1400 and almost 2000 when the AC is on.i have replaced the IACV and put a new distributor in it.one thing I did notice is when I disconnect the throttle position sensor harness an plug it back on with the car on the idle goes back to normal
Life is like a box full of shenanigans
8Nismo9 is offline   Reply With Quote
Old 05-04-2012, 12:51 AM   #2
8Nismo9
8Nismo9's Avatar
anyone got anything?
Old 05-12-2012, 06:15 PM   #3
8Nismo9
8Nismo9's Avatar
someone chime in
Old 05-12-2012, 06:30 PM   #4
ozzie7799
ozzie7799 is an unknown quantity at this point
I had a similar problem after I replaced the water pump of my car, which was weird. I tried to research the problem here, but didn't find much. When in park, I would hit the brake pedal repeatedly and I noticed the idle climb to nearly 2000 rpms. I checked my throttle position sensor harness and coolant temperature sensor harness and I noticed if I moved the wires, the rpms would drop back to normal. My KA24DE idles fine now, but I had that problem for a few months. A few weeks ago, it just went away and I haven't had the problem since.
Truthfully I don't know exactly what the problem was, but my best guess is the wiring on the throttle position sensor harness connectors. Just trying to help you out so you narrow down your issue.
ozzie7799 is offline   Reply With Quote
Old 05-12-2012, 07:20 PM   #5
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Im having the same issue...changed literally everything...entire im all harness no...even changed everything to obd1 im harness coolant temp o2 etc...same exact problem
Memberofthe600hpkaclub is offline   Reply With Quote
Old 05-12-2012, 11:08 PM   #6
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Is the ECU kicking out a code?? If so, which one, (s)??.
Ozzie may be correct in his guess of the throttle position sensor wiring harness. They don't last forever ya know.....They will go bad eventually. I learned this while fixing wiring harnesses for my friends.
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
