Old 05-03-2012, 10:48 AM   #1
Kaifd3s
Kaifd3s's Avatar
Kaifd3s is on the path to ruinKaifd3s is on the path to ruin
S14 Boost Issue
Alright the car is an S14 with a S14 SR. When I go WOT the car gets 7lbs and slowly creeps up to 11. Now the thing is anwhere below 4500 the car instantly gets the 7lbs and stays dead on it. After about 4500 the boost creeps up to 11 but stays there and doesnt increase. Is this just normal creep? I thought if it was creep it would keep rising.
Thanks,
ALI
Kaifd3s is offline   Reply With Quote
Old 05-03-2012, 10:59 AM   #2
KendallH
KendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choices
What are you running for boost control? If someone installed the factory boost solenoid I believe that is its correct function
KendallH is offline   Reply With Quote
Old 05-03-2012, 11:09 AM   #3
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
Sounds like what mine used to do. I'd say normal.
97 240sx se
0wn3r is offline   Reply With Quote
Old 05-03-2012, 12:33 PM   #4
Kaifd3s
Kaifd3s's Avatar
Where is the solenoid placed? Stock ECU, no boost controller.
Old 05-03-2012, 01:13 PM   #5
ultimateirving
ultimateirving's Avatar
unlikely its a stock boost solenoid, normally they are not shipped over with the motorsets because the part is attached to the chassis. I think what ur seeing is pretty normal. look to see if you still have the stock WGA on the turbo.
Z32 with lq4 swap
Old 05-04-2012, 11:58 AM   #6
Kaifd3s
Kaifd3s's Avatar
Yea I still have the stock actuator on the turbo. What if I change out to one of those HKS wastegates? Would I get a steady boost pattern?
Old 05-04-2012, 12:47 PM   #7
can24
can24's Avatar
can24 is an unknown quantity at this point
youll have a better boost pattern ,
your actuator is most likky going out
i recommend to change it, because my friends boost gauge was doing the same thing
,we replaced it and it was good but he got the stock actuator but i rather get the hks one
can24 is offline   Reply With Quote
Old 05-04-2012, 09:20 PM   #8
EJ8 944
EJ8 944's Avatar
EJ8 944 is an unknown quantity at this point
Check your engine bay to see if you have the factory boost control solenoid, there's been debate on whether the solenoid is only to help spool up time (with max boost at 7psi) or if the boost solenoid increases boost to 10-11psi.
Should be along the vacuum hose going to your wastegate actuator.
I'm interested on the results, I haven't read any solid proof anywhere about this matter.
EJ8 944 is offline   Reply With Quote
Old 05-05-2012, 10:22 AM   #9
Kaifd3s
Kaifd3s's Avatar
I will try my best. Ill look through it when I go home (at work)
The funny thing is that until 4500 where it slowly goes up to 11lbs, its only at like .4 BAR which is like 5 or 6lbs not 7.
I have a Defi gauge so I recorded a coulpe WOT runs and was looking at them.
