Old 05-08-2012, 06:00 PM   #1
bluezenkis14
bluezenkis14 is an unknown quantity at this point
Power door locks on my s14
I have google searched this but no one seemed o have the exact problem I have
My main problem is that my drivers side door lock will lock with out a problem but when I try to unlock it with either the interior switch or keyless fob it seems to almost but not unlock and I am forced to use my key to unlock the door I saw somewhere that the actuator needs to be tightened? Can anyone give me more information on that? And also my passenger side door will not unlock with my key but will work electronically
Thanks
bluezenkis14 is offline   Reply With Quote
Old 05-08-2012, 07:02 PM   #2
bluezenkis14
...Anything?
Old 05-08-2012, 08:16 PM   #3
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
have you removed the door panel for an initial inspection
dawagarage is offline   Reply With Quote
Old 05-09-2012, 06:11 AM   #4
bluezenkis14
Yes I have I didn't really see much I tightened the screw that holds the two rods on the top left of the door that's about it though
Old 05-09-2012, 08:30 PM   #5
bluezenkis14
Problem fixed (it was a little ghetto) but all I had to do was bend the lock rod that goes from the lock knob to the pivot point the knob still doesn't travel as far as it should but it works now. for anyone in this future with the same problem don't just go bending the rod and what not rule out all other problems first make sure the pivot point is lubricated and tight on the door
Old 05-09-2012, 08:47 PM   #6
JasianBlazin
Trader Rating: (24)
JasianBlazin is an unknown quantity at this point
Feedback Score: 24 reviews
hmm thanks for the info.
I also have to use my key to unlock my passenger side.
JasianBlazin is offline   Reply With Quote
Old 05-09-2012, 08:53 PM   #7
Jonathong
Jonathong's Avatar
Jonathong is an unknown quantity at this point
But those are gentlemen points when you have to do that for a female ahah
Sent from my SGH-T959V using Tapatalk 2
Jonathong is offline   Reply With Quote
Old 06-15-2012, 04:53 AM   #8
Tkoppab
Tkoppab's Avatar
Trader Rating: (22)
Tkoppab is an unknown quantity at this point
Feedback Score: 22 reviews
I was having the same problem. My actuator was taking a dump and i would have to lock and unlock it to make it work or sometimes use the key. I went down to my local junkyard and grabed one out of a G20 from around the same year. Bolted and plugged right in and now no issues whatsoever. Just a little input.
Tkoppab is offline   Reply With Quote
