Old 11-28-2010, 12:25 PM   #1
Sileighty_85
Sileighty_85's Avatar
So I Beleive I Just Solved The Infamous S14 Tach Glitch
Sorry Guys I like to tell stories on how i figure shit out haha
The Story:
So while ago I noticed my Tach was glitching (bouncing around and reading way higher than I was actually reving at) while Im driving and then began to just Peg out at 8K as soon as the engine starts.
I knew it was Tach related and not wiring cuz if i hit the dash it would Peg out if it was bouncing around.
So i pulled it out today to check it out and see if I could find anything oblivious wrong with it.
Well couldnt see anything that stood out so with the engine running and custer pluged in I was doing the "Wiggle Test" well when i was screwing in the Tach "Signal" screw I noticed that the Tach would jump.
Pulled out the Tach and inspected the Signal screw solder points to see that i looked like the Solder points were cracked.
The Fix:
Just took a Soldering Iron to the solder joints of the screw plate and bam she worked again! Dont Add Solder just "Re-Melt" Them
So if you got this issue try this before trying to source a "Newer" Tach.
Its Free and Easy
FYI: This was for a Kouki S14, Not sure if the Zenki is the same way, But just look for the Words "Sig" on the top side of the board
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-28-2010, 12:28 PM   #2
Ceepo
Ceepo's Avatar
Nice, good write up, ill keep this in mine if my tach does this ever, i havn't had any issues with it yet...
Old 11-28-2010, 12:49 PM   #3
holemilk00
holemilk00's Avatar
Trader Rating: (33)
holemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the rough
Feedback Score: 33 reviews
sweet the car I just bought is doing the same thing, I'll have to try this out. haha
I had a cool signature
holemilk00 is offline   Reply With Quote
Old 11-28-2010, 01:02 PM   #4
Sileighty_85
Let me know if this works to see if its just not mine
後輪駆動車1番
1986 SR86 - 200ish
Old 11-28-2010, 02:45 PM   #5
sal240sx
sal240sx has a spectacular aura aboutsal240sx has a spectacular aura aboutsal240sx has a spectacular aura aboutsal240sx has a spectacular aura aboutsal240sx has a spectacular aura aboutsal240sx has a spectacular aura about
Send a message via AIM to sal240sx
Mine started doing the same thing recently, was just too lazy to inspect. Thanks for the heads up.
sal240sx is offline   Reply With Quote
Old 11-28-2010, 08:31 PM   #6
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
on the topic of tachs what did you do to have the correct tach readout for your rb swapped s14 sileighty?
redline racer510 is offline   Reply With Quote
Old 11-28-2010, 10:07 PM   #7
Sileighty_85
There is a Potentiometer on the Tach that you can use to adjust it.
I dialed it in by ear but think its a little off, cuz 5,000 RPM's sounds like 8,000 unless thats just how RB's are
I have an Aftermarket Tach I'll probably wire up to calibrate it better
後輪駆動車1番
1986 SR86 - 200ish
Old 11-29-2010, 09:12 AM   #8
S14DB
AFC #1
S14DB's Avatar
Mine just started doing this. Going to Re-Flow that joint before I go hunting for a new tach...
Thank You for posting this.
Old 11-29-2010, 09:32 AM   #9
Mirage
Mirage is making a name for him/her selfMirage is making a name for him/her self
Send a message via AIM to Mirage
Sorry to be a killjoy but the UK guys have been doing this on SXOC for awhile . Those UK guys get cluster problems way worse than we do.
Good info to share nonetheless, i'm sure it will help people out.
It fixed my tach bouncing like crazy between 3500-5500, but I think I overheated it because afterwards the needle was slow, I would bounce off the limiter at 7500 when the tach was only at ~6900, but if the rpms were steady they would read fine (matching with PowerFC rpm readout). I ended up mixing and matching parts from clusters I already had laying around to keep my 7000 rpm redline tach and 260 km/h speedo
Mirage is offline   Reply With Quote
Old 11-29-2010, 10:32 AM   #10
Sileighty_85
NP
I hope if fixes your issues
Well i dont go on the UK fourms and not too sure how many other ppl do here.
I search quiet a bit when it started happening only to find ppl saying to source a used tach that worked.
後輪駆動車1番
1986 SR86 - 200ish
Old 11-29-2010, 11:02 AM   #11
mendozasport
mendozasport's Avatar
mendozasport is an unknown quantity at this point
i also think its a kouki only problem havent seen any zenkis doing this but dont hold that against me i could be wrong
mendozasport is offline   Reply With Quote
Old 11-30-2010, 09:19 AM   #12
S14DB
AFC #1
S14DB's Avatar
I found this last night.
S14a speedo gauges - SXOC Bulletin Board
Old 12-02-2010, 03:50 PM   #13
S14DB
AFC #1
S14DB's Avatar
The Screw posts looked intact but the signal one was low on solder. The motor mounts looked to have a lot of flux on them.
I re-flowed all of them. Cooked off the flux off the motor connectors and it still acts up. It doesn't slam into the clock post and hover at 8k. It only goes to 7k. idles about 1k lower too at 2500-3k. I think I'm going to give up and hunt for a new tach.
Old 12-02-2010, 04:56 PM   #14
Sileighty_85
damn that sucks to hear I was hoping that would be it.
Maybe just on some tachs?
But hell still worth a shot before getting another one
後輪駆動車1番
1986 SR86 - 200ish
Old 12-06-2010, 04:00 PM   #15
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
i have pretty much the same problem bouncing tach imma try this tomorrow afternoon and see if it the issue. i kind of figured it to be something like this seeing as how on cold days it will work. but as it heats up it starts getting all jumpy. ill do a step by step write up with pictures to help out.
P-Funk alot is offline   Reply With Quote
Old 12-06-2010, 04:11 PM   #16
S14DB
AFC #1
S14DB's Avatar
I put another cluster in and it reads fine. Guess I have to go tach shopping.
Old 12-06-2010, 04:35 PM   #17
holemilk00
holemilk00's Avatar
Trader Rating: (33)
Ok I did this, and it fixed my problem. All I had to do was basically touch my iron to the contacts and pull away. I put the cluster back in and it works great. Thanks again man, good find.
Old 12-08-2010, 08:36 PM   #18
koukistylejdm
koukistylejdm's Avatar
koukistylejdm is an unknown quantity at this point
hope it could work on a silvia kouki it does the exact same problem sometimes hit 8k on idle n stuff like that i will try it
koukistylejdm is offline   Reply With Quote
Old 12-09-2010, 06:26 PM   #19
jtmny1999
jtmny1999 is an unknown quantity at this point
Good info thanks!
jtmny1999 is offline   Reply With Quote
Old 05-16-2011, 12:05 AM   #20
SLEEPYDUB
SLEEPYDUB is an unknown quantity at this point
Pat, what about if your gauge works just fine, but just reads higher than the actual rpms? It seems to work fine, but when its at say 2000rpm, its readying around 4000, and it even gets into redline with normal driving, i mean its way off. Do you think this could be the fix for that too?
SLEEPYDUB is offline   Reply With Quote
Old 06-21-2011, 06:45 PM   #21
DriftEmperor88
DriftEmperor88 is an unknown quantity at this point
Your fuckn awesome. I would love to keep reading about your stories for they will help me in the future!!
DriftEmperor88 is offline   Reply With Quote
Old 06-21-2011, 06:58 PM   #22
Sileighty_85
haha thanks guys, unfortunately it seems like it was only a temp fix for me
Mine started messing up again a few months ago, I pulled the Tach again and re-flowed all the major points again, but no luck, I think It might be an issue with the tach motor
Im thinking about trying to use some Zenki components to see if I can fix the Kouki one since Kouki clusters are more scarce/expensive
EDIT: NVR mind didnt realize the Zenki Cluster was so different
後輪駆動車1番
1986 SR86 - 200ish
Old 06-29-2011, 08:27 PM   #23
DriftEmperor88
damn that sucks. Well i just fixed mine. lets hope mine last forever!!
oh yeah and for the guy above me. mine was doing that for a little while and then start jumping all over the place again. so it might just work. doesn't hurt to give it a try unless you totally just blow and mess everything up haha. its pretty simple but takes time 15mins for me.
Old 05-17-2012, 02:56 PM   #24
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Has anyone ever come up with an official solution to this problem? Yes I know you can just replace the cluster, however Im not just looking to replace the problem I would like to actually fix and solve it.
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 05-18-2012, 09:35 PM   #25
240zach
240zach's Avatar
240zach is an unknown quantity at this point
@Sileighty_85
check out my thread if you could and put in your .02.. cause i have no idea wtf is goin on. lol
http://zilvia.net/f/tech-talk/448700...ach-issue.html
240zach is offline   Reply With Quote
Old 05-20-2012, 02:25 PM   #26
Okinawandrifter87
Trader Rating: (22)
Hey Sileighty did you try this as well?
http://zilvia.net/f/s-chassis/382091...-problems.html
Driftphreak87
Old 05-20-2012, 07:05 PM   #27
240zach
240zach's Avatar
^^wtf are you doing? just posting stupid shit?
Old 07-17-2012, 07:39 PM   #28
Breitling
Breitling is an unknown quantity at this point
The Story:
The Fix:
Its Free and Easy
Old thread bump.... what points is he referring to?
Ls460, 240sx, Super Avenger, Chronofighter, Navitimer
Breitling is offline   Reply With Quote
Old 07-23-2012, 07:27 AM   #29
Skilz10179
Skilz10179 is an unknown quantity at this point
Probably the two with red circles around them...
Skilz10179 is offline   Reply With Quote
Old 07-23-2012, 02:43 PM   #30
1slowsilvia
1slowsilvia is an unknown quantity at this point
THANK YOU THANK YOU THANK YOU!
I was was in doubt like man this isnt gonna work
reflowed and it kept small hope.... and bam worked!
you are the man!
1slowsilvia is offline   Reply With Quote
s14 tach, s14 tach 8k rpms, tach broken
