Old 06-07-2012, 03:50 PM   #1
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Wheel Hop during launch, drag racing?
So I went to the drag strip, and my car wheel hopped like crazy. I have aluminum subframe spacers, all adjustable links, tein coilovers, and a Cusco 1-way diff...
What else can I do to cut down on wheel up when launching at the drag strip?
I was so frustrated with my time, I am completely plagued by the 13's. I went 13.01 @ 111 multiple times. I keep cutting like 2.2 and 2.1 60's. Cut 1 2.0, but missed a gear. I know the car can do 1.9's I just gotta get it down!
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 06-07-2012, 04:20 PM   #2
locoluna825
locoluna825's Avatar
locoluna825 is an unknown quantity at this point
Didnt think were coilovers are a good choice for those wanting to make better 1/4 mile times....? I thought that you needed softer suspension in the rear for that.
locoluna825 is offline   Reply With Quote
Old 06-07-2012, 05:25 PM   #3
jr_ss
Get rid of your spacers and put solid bushings or new bushings in. Me thinks your subframe bushings are toast and you'll still see wheel hop with spacers.
Old 06-07-2012, 05:52 PM   #4
boosted KA24DE
boosted KA24DE's Avatar
Trader Rating: (22)
boosted KA24DE is an unknown quantity at this point
Feedback Score: 22 reviews
^+1 on that after doing solid bushings car just tucks and moves. No matter what kind of spacers you choose , if the oem joint are toast you are wasting your time. leave coils on full soft and do not preload springs.
JDM Fashion isn't always good!
boosted KA24DE is offline   Reply With Quote
Old 06-07-2012, 08:42 PM   #5
turbociv910
turbociv910 is an unknown quantity at this point
you guys couldn't be more wrong with leaving coils on full soft.
www.carolinadyno.com
s13 LSx turbo drag car- 1.42 60 ft, 6.32 1/8
turbociv910 is offline   Reply With Quote
Old 06-07-2012, 09:09 PM   #6
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
Care to explain? You want some squat, don't you?
LuckyX2 is offline   Reply With Quote
Old 06-08-2012, 04:51 AM   #7
jr_ss
You have no idea what you are talking about. Go back to your Honda.
Old 06-08-2012, 07:04 AM   #8
BlackZenkiS14
+1, you would only want stiff rear on a honda....or FWD car.
I ran my coils at full soft, I know the game, I just need to figure out how to eliminate wheel hop.
-Kyle
Old 06-08-2012, 07:31 AM   #9
LuckyX2
LuckyX2's Avatar
Lol yeah, I figured he was confusing FWD and RWD.
FWD you want the rear stiff so it doesn't squat and lift the weight on the front tires. RWD you want as much squat as you can to put weight on the rear tires. I just thought I'd give him a chance to realize that on his own tho.
But back to the topic of wheel hop...
How's the surface at where you're dragging? I'm no drag pro by any means but that would affect wheel hop, right? What tire pressures are you running? what rpm are you launching at? What size/model tires do you have? Do you have the rear stripped?
And seconded on the solid bushings. Just don't put any of the shims in if you go with something like SPL. That will decrease your squat.
Old 06-08-2012, 08:09 AM   #10
BlackZenkiS14
Surface is concrete with VHT applied after water box. I dont go through water box.
I ran 30PSI in 255/40/17 Falken FK 452's. Launch at 4.5Kish, back of the car is stripped minus the cage, nothing in trunk but battery and sub.
-Kyle
Old 06-08-2012, 08:22 AM   #11
jr_ss
Do you slip the clutch or dump it? Preload suspension drivetrain at all?
Old 06-08-2012, 08:24 AM   #12
BlackZenkiS14
Definitely slipping the clutch, Not sure what you mean by preload the suspension drivetrain?
-Kyle
Old 06-08-2012, 08:33 AM   #13
LuckyX2
LuckyX2's Avatar
You can and should go lower than 30psi. Having such a light rear isn't helping things either. Can you move your seat back a little further? Where are you at HP wise?
Old 06-08-2012, 08:46 AM   #14
BlackZenkiS14
I dont want to go lower than 25psi on the tires, they arent drag radials lol. They are Z rated street tires.
But My seat can't go back further with me being able to effectively control the car.
HP is probably at 280WHP if I had to guess...maybe 300.
-Kyle
Old 06-08-2012, 08:58 AM   #15
LuckyX2
LuckyX2's Avatar
Well yeah, I wasn't talking about 10psi or something ridiculous, just something a little better than 30 like 20-25psi.
That's just a band-aid until you take care of the subframe bushings tho. That's pretty much THE cause of wheel hop, worn suspension bushings/components. Plus, those spacers you have in now are reducing your squat.
Old 06-08-2012, 11:47 AM   #16
jr_ss
Pull your ebrake then let your clutch out slightly, you'll feel the car load. Hold it there until your launch. Obviously you'll need to drop ebrake as you launch, just make sure your car is in gear. I honestly think you need to slip more, you shouldn't be wheel hopping out of the gate if your doing it right. I was pulling 1.9 60s on street tires and the only way I would see a bit of wheel hop was if I screwed the launch, i.e. too much throttle/ not enough slip.
You need to get the rear suspension addressed though. It's not helping your cause.
Old 06-08-2012, 01:21 PM   #17
S@nt0s
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
Sorry boss but thats not true, Look at any of the big HP drag cars on IRS Mustangs, Vetts' Vipers they have little to no squat. 240's,Supras,RX7's have a lot of squat but its at a lost. the energy lost from squating shouls be transfering to the wheels not lost in suspenion.bosy movement.
OP lower your tire PSI to 15-20 and dont launch it so high, drop your revs down and slip the clutch. the high PSI in the tires and high launch is causing a majority of the hop issue . check your bushings too as they could be worn.
MunkyW3rkz Racing
S@nt0s is offline   Reply With Quote
Old 06-08-2012, 01:36 PM   #18
LuckyX2
LuckyX2's Avatar
It was my understanding that you want some squat to transfer weight to the rear. This is incorrect? I understand what you're saying about energy being lost to the suspension but it is minimal, no? Once you get past the initial launch and compression of the rear suspension, you're not losing any more energy. At least that's how I see it.
If all the big power guys are running with minimal squat and it's working for them then I guess it must be right. That's on drag slicks though, I assume. Drag slicks have enough traction that you don't need to squat as much. It seems logical that you'd want more squat on street tires with less grip.
Old 06-08-2012, 01:48 PM   #19
S@nt0s
S@nt0s's Avatar
some yes but not like this
these guys have so much power they can do that LOL. but its lost motion plus a 28/10.5 helps lol
these here are Mustangs IRS on DR's
see the difference in suspension travel
MunkyW3rkz Racing
Old 06-08-2012, 01:53 PM   #20
LuckyX2
LuckyX2's Avatar
Oh well yeah, I didn't realize we were talking about wheelie levels of squat lol.
Obviously you don't want that. OP is under 300whp, has coilovers in the rear (which are presumably stiff) and squat reducing subframe spacers so I doubt there is a ton of squat going on.
It was my imagining that he was squatting very little and in that case could use a little more. I do agree that you don't want much more squat than those mustangs you posted tho.
Old 06-08-2012, 02:34 PM   #21
OBEEWON
OBEEWON's Avatar
Dude is right about the full soft thing. At least with dampening. Sag your springs. Full hard. Take some castor out your traction rods. Drop tire psi and pray for rain.
Factory bushings for the sub frame would help too.
Old 06-08-2012, 03:32 PM   #22
jr_ss
IRS squats, no matter what... It's going to happen. Sure you can limit the amount it does to an extent, but you can't prevent it.
Old 06-08-2012, 04:40 PM   #23
S@nt0s
S@nt0s's Avatar
never said prevent as a solid axle has some squat too , downward force/gravity will always win but it can be countered to help and minimize it.
Im stuck with stock suspension for now and will push that to its limit or whever i feel comfy with. in the meantime i will be building a nice custom rear set up with adjustable compression and rebound
MunkyW3rkz Racing
Old 06-08-2012, 05:19 PM   #24
jr_ss
I've seen people running extremely low times very minimal suspension. Ivan's 9sec 240 didn't have any crazy suspension work done. Hks drag coils, and those things are spongy...
Old 06-08-2012, 06:47 PM   #25
S@nt0s
S@nt0s's Avatar
Didn't say it couldn't be done but it can be made better
MunkyW3rkz Racing
Old 06-08-2012, 06:51 PM   #26
tabasco122
tabasco122 is an unknown quantity at this point
motor/tranny mounts can do it too. i have busted subframe bushings, but got delrin motor mounts and an alum tranny mount and i cut a 1.8 sec 60ft on street tires and an open diff. was pushing maybe 240-250hp. never got to run my car at the strip after the motor mounts, but the few times i launched it on the street there was absolutely no wheel hop.
tabasco122 is offline   Reply With Quote
Old 06-08-2012, 07:02 PM   #27
jr_ss
Street is no comparison for a prepped track... That shit is like tar paper.
Old 06-08-2012, 07:05 PM   #28
tabasco122
the car would wheel hop everywhere before the motor/tranny mounts...
Old 06-08-2012, 07:16 PM   #29
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
cars with tiny sidewalls dont give very much either. especially street compounds. when the tire cant give, it bounces. id definitely get a hold of a set of softer tires with more sidewall.
AsleepAltima is offline   Reply With Quote
Old 06-08-2012, 07:18 PM   #30
tabasco122
hankook ventus rs3 is an amazing tire for the price...
