Old 06-03-2012, 07:32 PM   #1
AlexSR
AlexSR is an unknown quantity at this point
Accidently used flexplate bolts on flywheel..
I purchased flywheel bolts but for some reason they weren't tightening properly (as I was tightening them they would get tight and then break loose, repeat) so I used the flexplate bolts because they threaded in perfectly, not thinking that it would make a difference reusing them.. but then I found out how much more longer the flywheel bolts are..
I still torque them all down properly to 105ft/lbs
Is it possible to get away with this? I havent had any problems so far..
Thanks.
AlexSR is offline   Reply With Quote
Old 06-03-2012, 07:34 PM   #2
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
i actually did this on a ka24de altima engine and ran it that way, turbo'd for like 35k miles.
AsleepAltima is offline   Reply With Quote
Old 06-03-2012, 07:37 PM   #3
AlexSR
Really?! Phew, makes me a whole lot less nervous lol thank you
Old 06-03-2012, 08:06 PM   #4
AsleepAltima
mine were marked - at and mt. i didnt realize i had them switched till they were torqued so i just said, f it. lol
as long as i could torque them and there wasnt a gap under the head, i was happy.
Old 06-03-2012, 08:14 PM   #5
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
1. a real concern is the fact that you may have already stripped the holes with the other bolts. When they were "breaking loose", they were probably actually stripping out the threads.
2. You should prob use the correct length bolts if possible. Thats a heavy piece of metal that moves very fast.
gotta240 is offline   Reply With Quote
Old 06-03-2012, 08:19 PM   #6
MrSanchez925
MrSanchez925 is an unknown quantity at this point
maybe slap a helicoil into the holes?
MrSanchez925 is offline   Reply With Quote
Old 06-03-2012, 08:53 PM   #7
jr_ss
Keep in mind if they ever shear off, or come loose, your legs and ankles are in zone... I'd put the right bolts in, then again I like my legs/ankles...
Old 06-11-2012, 02:34 AM   #8
sidewaysonmy180
sidewaysonmy180 is an unknown quantity at this point
^^^^^^^ agree 100% if done rite the first time. u won't waste your time doing it again the second time. My 2 cents
StAySiDeWaYz
sidewaysonmy180 is offline   Reply With Quote
Old 06-11-2012, 03:38 AM   #9
DJ-of-E
DJ-of-E's Avatar
DJ-of-E is an unknown quantity at this point
Where is that youtube video where the flywheel exploded and rip through the transmission and into the cabin?
Originally Posted by ocn View Post
its not "DRIFT" tax its a "IDIOT" tax Period!
DJ-of-E is offline   Reply With Quote
Old 06-11-2012, 10:11 AM   #10
N2HIFI
N2HIFI is an unknown quantity at this point
I useD the flex plate bolt when doing my rb swap, I've put 20k on the car in the last three years and lots of 80+ mph 3rd gear clutch kicks with zero issues... My option is I wouldn't stress it as long as they are TQ correctly
N2HIFI is offline   Reply With Quote
