Old 05-23-2004, 08:30 PM   #1
mike13
mike13's Avatar
mike13 is an unknown quantity at this point
Send a message via AIM to mike13
Fun with valve covers + OBX Header impressions
wow, this was a productive weekend.
check my thread at http://www.zilvia.net/f/showthread.php?t=54083 for pictures of my exhaust/ cat/ header install. Also pics of my wheels Nismo LM GT4's.
Anyways, today i decided to paint my valve cover black. Ive always wanted to do it and working on my car on friday gave me the itch to spruce up the engine bay a little bit. So i stopped at Advanced and picked up a bottle of brake cleaner and a bottle of High Temp engine enamel. Application was easy, i masked off a bunch of things like the oil filler cap recess and the spark plug holes. None of this is evident when those pieces are in place. I plan to have the letters grinded off when the paint cures.
on to the pics:
I think it turned out pretty good. Im going to hit it with some #0000 steel wool to clean it up a bit.
OBX HEADER IMPRESSIONS
before:
after 48 hours:
I think it looks pretty bad ass, but i have worries about the quality of it and whether it will crack or not. Overall for S14 i reccommend this header if you have a tight budget. Otherwise look into something made of higher quality steel and better fitment.
mike13 is offline   Reply With Quote
Old 05-23-2004, 08:44 PM   #2
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
I really am digging that black valve cover. Nice work on the header as well.
zero.counter is offline   Reply With Quote
Old 05-23-2004, 08:53 PM   #3
BadMoJo
BadMoJo's Avatar
BadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura aboutBadMoJo has a spectacular aura about
Send a message via AIM to BadMoJo
Lookin good!
----Gone----
BadMoJo is offline   Reply With Quote
Old 05-23-2004, 10:14 PM   #4
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
Nice job with the painted valve cover it looks really clean. I also want to paint my valve cover. What are your steps in painting the valve cover? Also what kind of stuff you use such as paint?
SilviaSR20DET is offline   Reply With Quote
Old 05-23-2004, 10:15 PM   #5
SimpleS14
SimpleS14's Avatar
nice...I have the same headers....how did you install the EGR tube?
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 05-23-2004, 10:15 PM   #6
Bbandit
Bbandit's Avatar
Bbandit is an unknown quantity at this point
Send a message via ICQ to Bbandit Send a message via AIM to Bbandit
wow that looks great man!
i've been meaning to do that to to my valve cover...
hmm prolly i'll do it in a couple of days..
I always liked flat black
==>>TGL GARAGE<<==.. RIP!
S13 coupe KA-T @ 0.5 Bar = SOLD!
A31 Cefiro + SR = Current
Bbandit is offline   Reply With Quote
Old 05-23-2004, 10:18 PM   #7
-E-
-E-'s Avatar
-E- is an unknown quantity at this point
wow looks good
-E- is offline   Reply With Quote
Old 05-23-2004, 10:19 PM   #8
kandyflip445
kandyflip445's Avatar
NOOOOOOO! You stole my idea for the valve cover! Cept' my idea included tellin ppl that i had a blacktop in my car.
My 240 vBgarage
Old 05-24-2004, 06:39 AM   #9
mike13
mike13's Avatar
Basically i sprayed half a bottle of brake cleaner on it to clean all the grease and grime off, then masked off a few areas with tape, hit it with heavy grit sand paper to score the factory "finish", then sprayed 4-5 coats with low gloss black engine enamel. no sanding or anything. I was really easy, just required patience.
Old 05-24-2004, 06:42 AM   #10
mike13
mike13's Avatar
First when we noticed it was in the wrong position, we were going to heat up the EGR extension on the header and bend it into place. When my brother hit it with the torch, he burned a hole straight through one side of the tubing. What we then did was patch it with a piece of stainless. We put the header into the engine bay, threaded the EGR tube in (it was a bitch even with the entire header free to move around). When the EGR tube was in place, we man handled the header onto the studs and tightened it down in place. Im sure this is putting stress on the tubing somewhere, but after a few days, i'm not too concerned about it cracking.
Old 05-24-2004, 06:49 AM   #11
mixxamike
mixxamike's Avatar
mixxamike is an unknown quantity at this point
Did you need to use a new valve cover gasket or did the old one work alright for you after you put the cover back on?
mixxamike is offline   Reply With Quote
Old 05-24-2004, 10:09 AM   #12
mike13
mike13's Avatar
they didnt have one at the parts store, so i just re used the old one. It was still very flexible and in good condition. This is the second time i've taken off the valve cover also.
Old 05-24-2004, 05:13 PM   #13
SilviaSR20DET
Hey when you put back in the valver cover did you know what torque spec it was? Also what torque spec are for the spark plugs anyone know?
Old 05-24-2004, 05:50 PM   #14
mike13
mike13's Avatar
Its in my FSM but i didnt check. I went by the tighten, then tighten some more method.
Old 05-25-2004, 11:11 AM   #15
Nismo240SX
Nismo240SX's Avatar
Nismo240SX is on a distinguished road
Send a message via AIM to Nismo240SX
i like the valve color... is it powdercoated, or spray can? looks good either way. the header is quite hillarious... my hotshot went dull after about 2 weeks.
1990 Nissan 240sx:s13 blacktop, s13.5 front
Nismo240SX is offline   Reply With Quote
Old 05-25-2004, 12:20 PM   #16
mike13
mike13's Avatar
It was a rattle can job but turned out better than expected (well i expected it to be good because I painted it)
Did your hotshot turn gold or just not shiny anymore? because you can polish yours and im not sure there is a way to make mine silver again.
