Old 07-19-2012, 12:39 PM   #1
jcanady
jcanady is an unknown quantity at this point
Sr20det Swap Idles But Will Not Rev
Ok, I just swapped a redtop Sr20det into my s13. Its a stock motor with a Gt28r turbo, HKS 555cc injectors, 255 fuel pump, and an RS Enthalpy ECU. I just got the Ecu back from Enthalpy. The car starts immediately and idles beautifully. When I rev it it will not go past 3000 rpm without misfiring and dropping back down in rpms. Since I havent gotten to the exhaust shop yet its basically dumping out underneath me so I can smell its very rich like unburnt fuel. I believe this is causing my problems. Does anyone have any ideas of why it wont rev like this? And yes, I have been researching. Thanks for any input!
jcanady is offline   Reply With Quote
Old 07-19-2012, 12:59 PM   #2
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
Get a wideband, itll really hard to figure out your problem without one, plus you need make sure your tune is safe
check wiring to the maf, thats usually the most common problem
c-los13 is offline   Reply With Quote
Old 07-19-2012, 01:03 PM   #3
jcanady
Yeah I checked the wiring to the maf and that doesnt seem to be the issue.
Old 07-19-2012, 01:19 PM   #4
jcanady
Well it could be the maf. Out of three wires in the loom, one gets 12v and the other two get nothing. Shouldnt one get 5v?
Old 07-19-2012, 03:59 PM   #5
ultimateirving
ultimateirving's Avatar
with the maf plugged in, koeo, if you probe the back of the maf, at least 2 of the wires should have voltage coming from them
Z32 with lq4 swap
Old 07-19-2012, 06:17 PM   #6
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
yea 2 will have power. and your car is going into limp mode.
godsmack is offline   Reply With Quote
Old 07-20-2012, 12:25 AM   #7
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
+1 on Maf problem.
Old 07-20-2012, 01:07 AM   #8
drift213
drift213's Avatar
drift213 is an unknown quantity at this point
^^^^^^^^^^^ +1
LOTS OF SR20,ka24de,s13 goodies for sale check my threds
drift213 is offline   Reply With Quote
Old 07-20-2012, 10:13 AM   #9
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
if wires check out
blk/wht...12v
wht...5 v
blk ground
then its the maf...
wat maf is ecu tuned for?
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 07-21-2012, 03:10 AM   #10
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i am having the same problem. shit wont rev past 3k-4k. about to re check my wiring again. pulled codes threw a 12 afm.
try to check the codes too
Old 07-22-2012, 08:40 AM   #11
jcanady
I checked the codes and all it does is the led light stays lit and wont blink which i'm assuming means Ecu malfunction. And its tuned for z32 maf which is what i'm using.
