Old 05-18-2004, 10:32 PM   #1
NismoSilvia270R
NismoSilvia270R's Avatar
NismoSilvia270R is an unknown quantity at this point
Send a message via AIM to NismoSilvia270R
check engine light
where is it on the head up digital dash. idk, might need adjusting, but my brake (e-brake) light stays on.
NismoSilvia270R is offline   Reply With Quote
Old 05-18-2004, 10:46 PM   #2
NinjaGaiden
NinjaGaiden's Avatar
NinjaGaiden is an unknown quantity at this point
might have something wrong with your brakes. is there no pedal pressure when u press on ur brakes? is your car braking alright?
mine went on after i put on stainless steel lines before i bled them. Once I bled them though, the light went away.
NinjaGaiden is offline   Reply With Quote
Old 05-19-2004, 01:50 AM   #3
Sil-Abc
Sil-Abc's Avatar
Sil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfection
Send a message via AIM to Sil-Abc
fill your brake master cylinder with brake fluid. simple as that
IM JON WAYNE ESQ.... bitch
Sil-Abc is offline   Reply With Quote
Old 05-28-2004, 10:43 AM   #4
NismoSilvia270R
funny. its full
Old 05-31-2004, 07:46 AM   #5
typhoonslippery
typhoonslippery's Avatar
typhoonslippery will become famous soon enoughtyphoonslippery will become famous soon enoughtyphoonslippery will become famous soon enoughtyphoonslippery will become famous soon enough
yeah I am having the same problem with my headsup display ...the Ebrake light stays on ....master is full and I have checked the ebrake switch and cables . I am out of ideas as well
CA18 is the only way to go!
typhoonslippery is offline   Reply With Quote
Old 05-31-2004, 08:19 AM   #6
NismoSilvia270R
typhoon,
do you have problems with your dash lights turning off?
and
what grill is that? hotness
Old 05-31-2004, 09:12 AM   #7
typhoonslippery
eastbear grille ....
umm ....right now ....my ebrake light is always on ....
and when I start the car ....the clock comes on and the tach and the fuel and no other lights
I drive for a while and the temp gauge comes on .....then the trip and odometer will come on shortly after ......then the illumination will come on and the digital speedo and HUD .......takes a while ....and is annoying but I hear it is a common problem ... Iwant to know if I need a new dash cluster to replace this or if it is one of the plugs into the back of it that is loose ...but it seems whenthe car warms up and is driven for a while it always comes on ....
Old 05-31-2004, 09:56 AM   #8
NismoSilvia270R
this is why i get other people to do my electrical crap.
eastbear, huh? nice
Old 05-31-2004, 03:59 PM   #9
typhoonslippery
hahaha I am just going to get another dash ...I figure the speedo and odometer are cluster problems ...will be hard to find a CA one though ...not many people buy CA clips ...
E-Brake light sounds liek a seperate problem ...will try messing with ebrake and fluids again
Old 05-31-2004, 07:30 PM   #10
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
check for a loose wire, ^^
WheelsDirty
Old 06-01-2004, 12:13 AM   #11
typhoonslippery
it is like when the car is run for a while things start working again ....like something needs to warm up or work in every time ....oh well ....I will pull it apart when I get some spare time and post if anything positive comes out of it
