Old 05-31-2004, 06:36 PM   #1
giant killer
giant killer's Avatar
giant killer is on a distinguished road
KA a few elec. q's..
first off.. i have been having serious problem getting my car started after putting the motor back in.. so today i started checking "everything".. well first thing i check are the fuses.. the 75 amp alternator fuse was blown.. could this affect say.. the brake lights?
is this a common problem and if so is there a common fix?
is this a dealer only fuse or should i be able to pick one up at napa?
second.. i relocated my battery to the trunk.. i am running a large 1/0 gauge wire from the back to the front.. i am wanting to redo how i have it setup.. would 4 gauge be big enough for the battery positive cable running rear to front?
thanks in advance... bennyb
giant killer is offline   Reply With Quote
Old 05-31-2004, 07:09 PM   #2
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
um usually fuses can be found anywhere, well maybe not taht big but im sure you will find it at any auto parts store. also if other lights are working, break lights should also.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 05-31-2004, 08:56 PM   #3
FastBack 240
FastBack 240's Avatar
FastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymore
4 gauge is sufficient but why not just go with a thick zero gauge?
FastBack 240 is offline   Reply With Quote
Old 05-31-2004, 09:19 PM   #4
mjjstang
unless you have the largest system in the world, 0 gauge is just a waste of lbs and money.
Old 05-31-2004, 10:00 PM   #5
giant killer
at most the car will have a cd head unit and the two door speakers.. i agree with mjjstang, 4awg is cheaper and weighs less.. plus the stinger distribution block i am getting is 4awg input.. yulp..
Old 06-01-2004, 02:10 AM   #6
FastBack 240
Cause the 2lbs is gonna kill ya? Just take a dump before you drive it will equal it out. But yea your right 4 should be suffiecient.
Old 06-01-2004, 07:18 AM   #7
lotusdrift
lotusdrift is an unknown quantity at this point
Send a message via AIM to lotusdrift
I just relocated my battery using the summit racing kit. It uses a 2 awg positive cable, and recommends 4 awg for running a ground cable all the way to the engine bay (which I did). Home depot/lowes has a pretty good selection of cables and fuses, although they were short on connectors for cables with this large an ID.
If an alternator fuse is blown, I would think that would affect the whole electrical system (never had one blow though, so could not say for sure).
lotusdrift is offline   Reply With Quote
