Old 05-31-2004, 08:00 PM   #1
Crab Walker
Crab Walker is an unknown quantity at this point
Send a message via AIM to Crab Walker
Question Whats the difference between a T25 and T28?
I heard that the t25 and the t28 both use the same turbine, so i was wondering what exactly is the difference between the two?
I was thinking of getting a t25/t28 hybird, .48 turbine, .60 compressior. but is that just the same as a t28?
I want the closest to Zero lag i can get.
Crab Walker is offline   Reply With Quote
Old 05-31-2004, 08:24 PM   #2
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
t28 is ball bearing eliminating much lag but SEARCH
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 05-31-2004, 09:22 PM   #3
TheTimanator
TheTimanator's Avatar
I was under the impression that not all T28's were ball bearing.....
Also, checkout www.cheapturbos.com for info on the T28
Old 05-31-2004, 11:33 PM   #4
GlacierFreeze
GlacierFreeze is an unknown quantity at this point
They're not.
You =
Me =
GlacierFreeze is offline   Reply With Quote
Old 06-01-2004, 02:54 AM   #5
bkfill
bkfill is an unknown quantity at this point
K! Is It Or Is It Not Ball Bearing Make This Clear Now!
S15 T28 Turbo(yes The Stock 1) Is It Ball Bearing!
if it aint broken, fix it(95 240/96 sr20)
bkfill is offline   Reply With Quote
Old 06-01-2004, 08:41 AM   #6
Crab Walker
I heard the T28 is the same as a t25/t3 hybird, is this true?
So the t25/t3 has the lag of a t25 and the power of a t3. correct?
Old 06-01-2004, 08:49 AM   #7
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
no. search.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 06-01-2004, 09:04 AM   #8
Crab Walker
am searching, thats where I heard t25/t3 was the same as t28
Old 06-01-2004, 09:22 AM   #9
Steeles
Steeles's Avatar
try the archives on Freshalloy or go to the specs page on heavy throttle. the turbo specs are on there.
Old 06-01-2004, 09:27 AM   #10
Steeles
Steeles's Avatar
this info is so easy i'll be nice;
Redtop T25:
Compressor: T-25, 60 trim 56mm BCI-1 compressor.
Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing.
Center Section: Journal bearings
S14 Blacktop T28:
Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing
Center Section: Ball Bearing
S15 Blacktop T28:
Turbine: Inco turbine wheel. Cast divider wall between turbine discharge and wastegate.
