Old 08-05-2012, 08:43 PM   #1
roushman90
roushman90's Avatar
roushman90 is an unknown quantity at this point
KA-T hesitation issue
Hesitation at ~1800k RPM. Just doesn't want to go over that. Kind of weird because I have done pulls up to 5k since I drove it. I'm thinking it could be timing, boost leak, MAF, ECU, etc. FYI, I've only had it installed a week or so, it has barely been driven first due to an overheating issue and now this hesitation/not boosting problem.
As for timing, what should I be around? I know stock base timing is 20 +or- 2. I retarded it back to ~14 that my friend said I should but I think it made the hesitation worse. Just not real sure about where I need my timing at. Any suggestions? Rules of thumb etc?
Boost leaks I need to look into tomorrow, MAF I cleaned a little but I don't know how to test. ECU I hope it isn't because if it is that is an expensive problem..
Any suggestions are appreciated. I've been lurking all over KA-t.org but I can't make a post as I'm still in the newbie period, can't make a thread.
My setup is basically stock SR setup, running stock boost
SR T25
Emance tuned for N60/370s/T25
N60 Maf
370cc SR injectors
Custom HMIC setup, No bov
Bottom mount Isis mani
stock SR elbow (slight leak from turbo elbow, where the tube would go into it
3" downpipe to test pipe to buddy club spec II
walbro 255
Have yet to get my boost gauge in to monitor that, waiting on a harness for my AEM wideband and also need to get my SAFC wired in.
roushman90 is offline   Reply With Quote
Old 08-05-2012, 08:50 PM   #2
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Are you using an SR20 rubber intake? If so does it have the spring in it to keep it from collapsing?
You really shouldnt drive it until you get your wideband and boost gauge working.
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 08-05-2012, 08:52 PM   #3
roushman90
roushman90's Avatar
Yes, I am using an SR stock rubber intake. It has the spring inside as well.
I'm not planning on driving it really until I do get those hooked up. The harness is at a friends, and I just need a fitting for the vacuum line to hook up the gauge.
Old 08-05-2012, 08:53 PM   #4
StryfeS13
It's Always Broken.
StryfeS13's Avatar
What are you spark plugs gapped at?
Gotta love Zilvia.
Old 08-05-2012, 09:14 PM   #5
roushman90
roushman90's Avatar
I have them at ~.044
Old 08-05-2012, 09:18 PM   #6
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Gap them to .028
Gotta love Zilvia.
Old 08-05-2012, 09:35 PM   #7
roushman90
roushman90's Avatar
I'll give that a shot in the morn, thanks for the suggestions.
Old 08-06-2012, 10:25 PM   #8
StryfeS13
It's Always Broken.
StryfeS13's Avatar
So did changing your plug gap help with your hesitation?
Gotta love Zilvia.
hesitation, issue, ka-t, ka24, turbo
