Old 08-09-2012, 06:39 AM   #1
Tempo
Tempo's Avatar
Trader Rating: (39)
Tempo is an unknown quantity at this point
Feedback Score: 39 reviews
S14 harness tuck DIY (cutting frame) step by step!!(wheel well tuck)
not sure if this is the right area to post this, please move to appropriate section please if not.
*Dislcaimer, I am not responsible for injuries due to poor safety and usage of tools/power tools, or damages due to poor worksmanship, DO NOT attempt if you think you cannot perform the tasks.
  • Ballin hard with your new rims but your harness is getting f**d?
  • Can't find a decent DIY thread to tuck your harness?
  • Making plans to super slam your car and you want to get ahead by tucking that annoying harness?
  • That tuck you already have still causing harness rub?
Well, here is the thread you've been looking for!
Novice steps(if you already have your fender off your car or know how to get to it skip to the pics and short tutorial comments)
  • Remove your headlights, grill, and corners
  • Remove all 12 screws(or less) along the top/side part of your support holding your bumper
  • Unplug all light connections on your bumper(sidemarkers/blinkers) and remove and set aside your bumper
  • Remove 9 screws holding up your fender 3 on top, 2 near door, 2 near corner light area, 2 near bottom rocker panel area.
  • At this point your fender is off(or should be -____- )!
Tools/Items I used
  • Protective gear
  • Side Grinder(sawzall would have been better but side grinder worked)
  • Primer
  • Duct Tape(yes i know, lol)
  • *Throw in any other steps you want to make it satisfactory to your project goal
mark where you want to cut(pic is piece already cut but put back into place for reference)
IMO it was the perfect size cut for the harness to fit into.
Chunk cut out, used the hammer to hit the chunk out because the side grinder would not reach
Primer the fresh cut to prevent rust
Finished product, i threw some duct tape over the primer after it dried so the edges of the cut wont cut into the harness.ziptie your harness using the holes provided by nissan ^^
Enjoy
IG - allen.kerose
Tempo is offline   Reply With Quote
Old 08-09-2012, 06:57 AM   #2
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
Awesome post, I should be doing this shortly.
How hard was it to put the fender back on over the harness?
thefro526 is offline   Reply With Quote
Old 08-09-2012, 07:05 AM   #3
xoxide
xoxide's Avatar
xoxide is an unknown quantity at this point
I applaud the effort, but that is a fucking hack job.
xoxide is offline   Reply With Quote
Old 08-09-2012, 07:43 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
+1093480938 Atleast smooth the damn edges. What makes you think the sharp edges wont cut thru the duct tape and the harness sleeve from all the vibration? Besides, you only showed a very small piece of the tucking process.
CLICK HERE!!!
Old 08-09-2012, 07:55 AM   #5
silviaks2nr
silviaks2nr's Avatar
don't use zip ties. use screw in harness clip/anchors with rubber gromets.
Old 08-09-2012, 08:38 AM   #6
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
not for anything but this has been covered over 100 times and you did the worst job possible
Old 08-09-2012, 08:56 AM   #7
Hiighboost2
Hiighboost2's Avatar
Trader Rating: (32)
Hiighboost2 is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to Hiighboost2
I was expecting something a bit cleaner..
Instagram @hiighboost @iasperformance
Hiighboost2 is offline   Reply With Quote
Old 08-09-2012, 08:59 AM   #8
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
This is not the thread I've been looking for.
Old 08-09-2012, 09:30 AM   #9
SuperBlackS14
SuperBlackS14's Avatar
SuperBlackS14 is an unknown quantity at this point
Was expecting something a bit more comprehensive, good effort tho.
"Power Is Nothing Without Control"
SuperBlackS14 is offline   Reply With Quote
Old 08-09-2012, 09:33 AM   #10
240drifter1
240drifter1's Avatar
240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute
Send a message via AIM to 240drifter1
Bahahahahahahahahaha!!!
240drifter1 is offline   Reply With Quote
Old 08-09-2012, 10:49 AM   #11
STL240SXDRIFT
STL240SXDRIFT's Avatar
STL240SXDRIFT is an unknown quantity at this point
Boo this man
STL240SXDRIFT is offline   Reply With Quote
Old 08-09-2012, 11:23 AM   #12
dtfdanyo
dtfdanyo's Avatar
dtfdanyo is an unknown quantity at this point
nice job taking the time to do a write up, but that shit ratchet.
tEAM tUCK
dtfdanyo is offline   Reply With Quote
Old 08-09-2012, 02:53 PM   #13
Tempo
Tempo's Avatar
Trader Rating: (39)
slipped right on without any problem
meh its hidden under the fender long as i got the piece out, first time cutting. one day ill come back to eventually when i become pro at pro cutting
^^^ see above, works out for my buddies who did it themselves no problems in the 5 years theyve had it like that. True, I rushed the thread before i went to sleep, so ill add more detail to the tuck when i get more pictures.
zipties work fine but if screws work for you then have at it.
how so? because my cuts were off by a quarter inch? or i didnt smooth out the edges? please elaborate.
more info to come
rushed thread before i slept , ill add more info when i can.
IG - allen.kerose
Old 08-09-2012, 02:59 PM   #14
kasted
kasted's Avatar
kasted is an unknown quantity at this point
hella ratchet
http://fb.com/driftsociety <-- sd street drift crew like it
kasted is offline   Reply With Quote
Old 08-09-2012, 02:59 PM   #15
fliprayzin240sx
Wow...I like this guy. Most kids around here would be resorting to name calling and cussing people out after getting critiqued like this.
CLICK HERE!!!
Old 08-09-2012, 03:17 PM   #16
Tempo
Tempo's Avatar
Trader Rating: (39)
thanks! , I kinda saw it coming though because i didnt smooth out the edge like i wanted to and just opted for the duct tape like my friend did.
Lack of pictures from dirty covered hands from other things done that day and poor lighting when the sun went down also was a no-go , hopefully...
i get more pictures during the day to add more detail to the thread.
IG - allen.kerose
Old 08-09-2012, 07:39 PM   #17
blueshark123
Trader Rating: (55)
yea you could have cleaned up the edges and done a better cut out job. Also painting over the cut would help prevent from rust forming.
Old 08-09-2012, 09:14 PM   #18
fliprayzin240sx
^^^Well, he did say he rattle primered it.
CLICK HERE!!!
