Old 08-09-2012, 12:28 PM   #1
Paparazzi
Paparazzi is an unknown quantity at this point
Chase Bays Power Steering Cooler
Anybody know if on these ends I should use any thread sealant of any type? These are standard end fittings with no seat when threaded in so something must be used?
Paparazzi is offline   Reply With Quote
Old 08-09-2012, 12:39 PM   #2
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
I use thread sealant on everything that could leak. It's called extra protection and learn to use it.
Hashiriya415 is offline   Reply With Quote
Old 08-12-2012, 01:04 PM   #3
Paparazzi
I have read many times that sealant is a no no. What type did you end up using?
Old 08-12-2012, 01:36 PM   #4
!Zar!
!Zar!'s Avatar
It depends on what type of fitting they use will determine if thread sealant is used or not.
But my guess is no thread tape should be used.
Old 08-12-2012, 01:56 PM   #5
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
If it is an AN fitting, there is no need for any type of sealant. However I use teflon tape on NPT/pipe fittings.
garagelu is offline   Reply With Quote
Old 08-13-2012, 01:52 PM   #6
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
Correct!!!!!!!
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 08-13-2012, 01:58 PM   #7
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
jesus. teflon tape is NOT a sealant. it is a LUBRICANT for NPT fittings that is meant to lubricate the threads so that you can tighten it more. notice how much more you can crank down on a fitting with tape on it. so dont THINK of it as a sealant. its not meant to seal. think of it as a lubricant and to only use a little bit and you will have less leaks.
ch1873857 is offline   Reply With Quote
Old 08-13-2012, 02:04 PM   #8
S14DB
AFC #1
S14DB's Avatar
You shouldn't use Teflon tape. Use liquid sealant if you have to.
The kit should come with copper washers.
