Old 08-10-2012, 09:14 AM   #1
ansemenoff
ansemenoff's Avatar
ansemenoff is an unknown quantity at this point
bearing/hubs questions
hey so there is a pretty substantial knock coming from the front of my s14 Silvia and I believe it is the hubs. I tried testing them and they needed to be repacked but all in all ok is there something else that it could be? Its definitely not tie rods or tension arms. And if I do need to replace is an s13 hub supposed to fit on my spindle because the s13 beatings were too small when I tried two days ago
ansemenoff is offline   Reply With Quote
Old 08-10-2012, 04:34 PM   #2
Sileighty_85
Sileighty_85's Avatar
S14 front bearings are diff and not replaceable you need to buy the whole hub.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-10-2012, 07:02 PM   #3
ansemenoff
ansemenoff's Avatar
Yes I know that but I'm not sure the hub is even the problem is there a better way to test them that just grabbing the wheel and shaking it?
Old 08-11-2012, 07:22 PM   #4
Srjustin
Srjustin is an unknown quantity at this point
The wheele off and take the caliper and roder off and turn the hun if it makes
noise or feels loose brobly your hub.
Srjustin is offline   Reply With Quote
Old 08-11-2012, 09:54 PM   #5
kouki_drifter
kouki_drifter's Avatar
kouki_drifter is an unknown quantity at this point
Check your suspension coilovers/struts for play could be a bad strut does it only happen when you hit bumps or turn?
kouki_drifter is offline   Reply With Quote
Old 08-12-2012, 02:36 PM   #6
ansemenoff
ansemenoff's Avatar
Only on bumps. could it be from having my coil overs jacked up all the way so I could simulate factory ride height for my inspection? Cuz the ride is way stiffer than I have ever had it
Old 08-16-2012, 12:25 PM   #7
kouki_drifter
yea that sounds like a suspension issue, i would check them out im sure thats what it is.
Old 08-24-2012, 12:15 PM   #8
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
check your front top hat, my s13 was really bad, took my 2 pairs of front tires to figure it out. take off front struts and check for play on the top hat, mine were really bad side to side play.
FS: DSS 1pc Steel Non ABS, 6bolt axles
WTB: Boost Gauge, Hatch Roof Wing
tapdeznutz is offline   Reply With Quote
Old 08-24-2012, 12:23 PM   #9
ansemenoff
ansemenoff's Avatar
I would love for it to be that easy but guess who just replaced his top hats 5 months ago haha they were the cause last time but not anymore. Good thinking though. One thing I did do was lower the car some more which took tension off the spring and the big loud bang is gone but im now hearing a soft quick almost rattle coming from that same side now
Old 08-24-2012, 01:27 PM   #10
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
also do not forget about engine and trans mounts. when i first got my car about a year ago, it clunks really bad. found out it was bad trans mount. then i did DIY urethane motor mounts and went to install them and my passenger side motor mount just fell apart when i went to removed it lol. just logically think it out. DAMN these old cars, its like a love hate relationship. i love the car just hate spending all this money on it lol. good luck.
Old 08-24-2012, 02:07 PM   #11
ansemenoff
ansemenoff's Avatar
Haha hanks that's also a good idea I will certainly test that and yes I love it to death but oh how I just wanna kill it
bearings, hubs, knock
