Old 09-08-2012, 08:29 PM   #1
edmorl
edmorl's Avatar
Trader Rating: (24)
edmorl is an unknown quantity at this point
Feedback Score: 24 reviews
broken tension rod bracket bolt
Attempted to remove the stock tension rod brackets to replace them with a nismo power brace. On the passenger, there are 2 bolts that hold up the bracket to the rad support, well one of those broke. There's about 2 threads sticking out. What's the best way I should go about doing this ?
I doubt an easy out would work because the bolt was very seized, but it turned with a lot of force. Maybe drill it out and tap it ? but it would be hard to drill it dead center.
Anyone ever been in this situation before ?
edmorl is offline   Reply With Quote
Old 09-08-2012, 09:05 PM   #2
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
Use Vise-Grip (should be called Death-Grip) pliers and clamp them on there real tight, that should get it out rather easily. I'd recommend the original ones by Irwin. I was able to remove a couple rusted out exhaust bolts with them after rounding out the bolt heads and nuts with regular sockets. Another option is to use an Alden GraBit extactor, I have one and it's a great piece.
omgRWDgoodness! is offline   Reply With Quote
Old 09-08-2012, 09:30 PM   #3
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
Weld on a nut and loosen it.
Hashiriya415 is offline   Reply With Quote
Old 09-08-2012, 10:13 PM   #4
edmorl
edmorl's Avatar
Trader Rating: (24)
There's not enough sticking out to grab it with vice grips
I'll try to find a welder, mine's broken. I'm trying to find an alternative
Old 09-11-2012, 01:00 PM   #5
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
Welder is your only option,
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 09-11-2012, 02:16 PM   #6
240dream
240dream's Avatar
240dream is an unknown quantity at this point
try the easy out worth a shot maybe heat it up first
240dream is offline   Reply With Quote
