Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 07-24-2012, 08:04 PM   #1
jordaninnovations
jordaninnovations's Avatar
jordaninnovations is an unknown quantity at this point
Send a message via AIM to jordaninnovations
*STANCE SUSPENSION PRODUCTS from Jordan Innovations!*
We at Jordan Innovations believe Stance makes some of the best suspension suspension parts on the market. With their use of AURORA joints and rod ends, beefy materials, and heavy R&D, are the reasons we believe it's one of the best products on the market.
Please contact us at 626-472-6360 or PM us for questions or pricing.
Stance SS
Features:
15-way dampening adjustable
Camber Plates
Pillowball Upper Mount
Cold Wound Linear Spring w/ 8k/6k Spring Rates
Inverted Montube Shocks
Height adjustable lower bracket
Stance SS+
Features:
Camber Plates
Helper Springs
Stance Pro Comp
Features:
12-way dampening adjustable
Camber Plates
Swift Springs with 8k/6k for S13 and 9k/7k for S14/S15
Helper Springs
Stance Pro Comp 2
Features:
Camber Plates
Helper Springs
20-way Compression Adjustable
Stance Pro Comp 3
Features:
Camber Plates
Helper Springs
15-way Low-Speed Bump & 4-way High-Speed Bump Adjustable
Suspension Components
Stance 240sx RUCA S13/S14
Features:
High Quality AURORA Spherical Rod Ends
Allows for proper camber adjustment
Stance S13/S14 Tension Rod
Features:
Billet Aluminum Construction for Strength
Stance Tension Rod is Zinc Coated for lasting duability
Grade 8 Hardware
Stance S13/S14 Traction Rod
Features:
High Quality AURORA Spherical Rod End w/ Pillowball
Allows for fine tuning to reduce bump steer
Stance S13/S14 Toe Rod
Features:
Allows for fine tuning of the cars Toe specifications
Chassis Components
S13 -> S14/S15 Subframe Conversion Bushings
Allows for better suspension adjustment
Perfect for lowered S-Chassis, by raising the rear subframe 10MM, these bushings will help correct your cars Roll Center.
Solid Aluminum Subframe Bushings
Replaces your S-Chassis old, squeaking suspension bushings
Removes play from old worn bushings
Provides a direct feel between you and your S-Chassis
Raises rear subframe just over half an inch to help aid in roll center
S14 Solid Aluminum Differential bushings
Replaces your S-Chassis worn differential bushings providing a more direct power transfer during acceleration and decel
S13/S14 Subframe Collars
Reduce sloppy feeling with your old worn out bushings
Provides better power transplant without replacing your old beat up bushings
Check us out on our website!
Make sure to check out Jordan Innovations on facebook!
jordaninnovations is offline   Reply With Quote
Old 07-26-2012, 03:05 AM   #2
Om1kron
Om1kron's Avatar
is it just me or did 2 other vendors blow up the front page of zilvia to push this to the bottom? lol
Wayne Edwards
https://om1kron.blogspot.com
Old 07-26-2012, 11:51 AM   #3
jordaninnovations
Thank you Wayne!
ALL PM'S RESPONDED! Thank you Zilvia
Old 07-31-2012, 12:38 PM   #4
jordaninnovations
All orders have been shipped, thank you everyone!
Old 08-01-2012, 11:36 AM   #5
jordaninnovations
All orders shipped! Thank you everyone!
Old 08-02-2012, 08:02 PM   #6
jordaninnovations
All Stance orders have been shipped!
Old 08-07-2012, 07:21 PM   #7
jordaninnovations
All Stance arm's have been shipped! Couple sets of coilovers too
Old 08-09-2012, 01:08 PM   #8
jordaninnovations
All PM's responded!
We also carry Stance's Fender Roller, which is perfect to get your wheel fitment where you want it to be! Get rid of that rubbing and fit you gangster wheels!
Old 08-17-2012, 02:22 PM   #9
jordaninnovations
Stance products are still available! Please PM us for best pricing on any damper set or arms!
Old 08-22-2012, 05:41 PM   #10
jordaninnovations
Stance parts are ready to ship! PM us for pricing
Old 08-30-2012, 12:41 PM   #11
jordaninnovations
All stance orders shipped! Arms have been moving like crazy!
Old 09-10-2012, 03:04 PM   #12
jordaninnovations
All Stance orders have been shipped! Make sure to check us out for the best pricing around!
Old 09-14-2012, 04:07 PM   #13
jordaninnovations
ORDERS HAVE BEEN SHIPPED!
Thank you everyone!
Old 09-17-2012, 01:32 PM   #14
jordaninnovations
ALL PM's RESPONDED! Thank you everyone!
