Old 06-11-2004, 11:41 AM   #1
blackkoukirps13
blackkoukirps13 is an unknown quantity at this point
Send a message via AIM to blackkoukirps13
what rear wheel bearings for 5 lug conversion on a s13
im putting 300zx rear hubs on my s13 and i dont know what wheel bearings i need. do i need s13 wheel bearings or z32 wheel bearings?
blackkoukirps13 is offline   Reply With Quote
Old 06-11-2004, 11:45 AM   #2
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
id like to hear this answer too...although, i think they would be the same.
CoasTek240 is offline   Reply With Quote
Old 06-11-2004, 11:56 AM   #3
omen2853
omen2853's Avatar
omen2853 is an unknown quantity at this point
when i put my 300zx rear hubs on they came with the bearing already attached. the holes from the 300zx bearing lined up with the stock holes on the s13 (where the s13 bearing was). so i would assume you could use either.
omen2853 is offline   Reply With Quote
Old 06-11-2004, 09:35 PM   #4
orion::S14
orion::S14's Avatar
Hubs and bearings are one peice for the S13/S14/Z32, etc...
Thery are a sealed unit, pressed in...cannot be changed or serviced.
When you buy 5-lug rear hubs, the bearings come with it, no exceptions.
- Brian
Old 06-12-2004, 02:38 AM   #5
blackkoukirps13
not me.....i have hubs with no bearings......the bearings can be changed if you have a machine to press them in with........i have a set of brand new 240sx rear wheel bearings but i wanted to make sure i could use them with the hubs. im not sure if they are the same or not.
Old 06-12-2004, 02:12 PM   #6
orion::S14
orion::S14's Avatar
Weird...never heard of such a thing.
I was under the impression they were sealed, not serviceable...?
??? - Brian
Old 06-12-2004, 03:27 PM   #7
Hawd
Hawd is an unknown quantity at this point
for the price of new wheel bearings you might as well buy a new hub.
Hawd is offline   Reply With Quote
Old 06-12-2004, 11:28 PM   #8
Slam
Slam has a spectacular aura aboutSlam has a spectacular aura aboutSlam has a spectacular aura aboutSlam has a spectacular aura aboutSlam has a spectacular aura aboutSlam has a spectacular aura about
I am on the same boat. I have a S13 and bought the S14 rear 5 lug hub only. Didn't purchase the S14 bearing. I will find out if it works when I get it apart.
Slam is offline   Reply With Quote
Old 09-28-2004, 10:53 AM   #9
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
answer this age old question....
so does this work? s13 wheel bearing work with S14 Hub
@woooster on instagram
kuruptR is offline   Reply With Quote
Old 09-28-2004, 12:59 PM   #10
projectRDM
projectRDM's Avatar
S13/S14/S15/Z32 rear hubs all use the same bearing. It is serviceable, though you need a press to get it out.
The fronts, S13s are serviceable, S14/S15 are not, they're one piece and not rebuildable.
FORMERLY R240NA
Old 10-25-2004, 02:21 AM   #11
FRpilot
FRpilot's Avatar
do s13/s14/s15/z32 rear wheels bearings/hubs look the same.
i have a set of s14 rear hubs and bearings and tonight i bought some z32 na hubs supposedly. i checked to make sure they were the same size and they were, but the hub on the z32 looked more of a rounder star than the s14. the only weird thing is was that on one of the z32 wheel bearings there seemed to be extra metal sticking out with a hole. is that normal? i figured i could just grind it down. do z32 and s14 wheel bearings look different?
FRpilot is offline   Reply With Quote
