Old 09-27-2012, 05:50 PM   #1
second_chanceS14
second_chanceS14's Avatar
second_chanceS14 is an unknown quantity at this point
Weird issue 95' KA24DE
So lately my car dies on me randomly. I did notice in the mornings sometimes the car tends to smell like gas but the smell would go away, car ran fine and everything but if i shut it off after a casual drive it will start then the idle will drop below 500rpms bogg then die. I normally have to wait 30 to 45 mins before i can get the car to start. Ive tried different MAFs, cleaned the throttle body, cleaned the air filter. My distributor cap and rotor were switched a little under a year ago and i have denso iridum spark plugs which i got back in 09 but these are supposed to last 100k which i know i haven't exceeded. Now i looked at posts that talk about idling but my problem is only after i shut off the car and try restarting it, once its running it runs normally. Could this be a bad injector maybe that stays open and by letting it sit there it allows the fuel to evaporate ? bad fuel filter? although it was replaced 4 months ago?? Any suggestions and input is highly appreciated. Thanks
They always go kouki or s15 front end. I say keep it G with the zenki
second_chanceS14 is offline   Reply With Quote
Old 09-27-2012, 06:47 PM   #2
bkt808
bkt808's Avatar
bkt808 is an unknown quantity at this point
coolant temp sensor
bkt808 is offline   Reply With Quote
Old 09-27-2012, 08:09 PM   #3
second_chanceS14
i just checked the injectors and they are all working correctly, i will replace the temp sensor tomorrow thanks bkt808
Old 09-29-2012, 01:07 PM   #4
santi5222
santi5222's Avatar
santi5222 is an unknown quantity at this point
Send a message via AIM to santi5222
fuel pump ? could be going bad
santi5222 is offline   Reply With Quote
Old 09-29-2012, 04:29 PM   #5
Poppadoc
Poppadoc is an unknown quantity at this point
I agree sounds like coolant temp sensor. My did the same thing, changed that problem solved.
Poppadoc is offline   Reply With Quote
Old 09-30-2012, 12:41 AM   #6
second_chanceS14
cant be the fuel pump cause once its gone its gone lol i replaced the coolant temp sensor, no problems yet
Old 09-30-2012, 06:24 PM   #7
second_chanceS14
ok so today the problem came back the car started up fine then once it was warmed up and i turned it off and turned it back on it started doing the same thing, i tried giving it gas but it just bogged and died.
Old 10-01-2012, 01:13 AM   #8
bkt808
bkt808's Avatar
i wonder if the fpr is getting stuck
Old 10-01-2012, 10:58 PM   #9
second_chanceS14
so i think i figuired it out, my ignition has play and sometimes the fuel pump doesnt come on, the car starts but since it only has the fuel left in the lines it dies right away. Another problem i found was the egr might be clogged so im going to replace that and seafoam that sucker clean
Old 10-30-2012, 09:57 PM   #10
BadIntentionS14
BadIntentionS14 is an unknown quantity at this point
I wonder if my Evap canister being gone is causing my issues.1995 SE All stock KA24DE except ebay exhaust and missing Evap can. I bought it that way and recently doing the same thing as yours too. Did you ever clean that EGR and did it help? Wouldn't a clogged EGR be the same as having an EGR block off plate?
How hard is it to replace the Coolant Temp Sensor?
BadIntentionS14 is offline   Reply With Quote
Old 11-01-2012, 09:28 PM   #11
hooknbook240sx
hooknbook240sx is an unknown quantity at this point
I am 90 percent sure its you're coolant temp sensor as you describe by your problem. This will cause running rich at idle and occasional rpm variance. If this is not the case I would say weak fuel pump. Hope you solve the problem
hooknbook
hooknbook240sx is offline   Reply With Quote
Old 11-01-2012, 09:31 PM   #12
hooknbook240sx
BadIntention- replacing the coolant temp sensor is fairly easy and is located next to the upper radiator hose near the intake manifold. If replacing the sensor is not the issue I would suggest cleaning the Evap cansister, replacing the fuel filter and or fuel pump, cleaning air filter and throttle body.
Old 11-01-2012, 11:59 PM   #13
BadIntentionS14
Thanks man I'm going to replace it, check for vacuum leaks, clean my throttlebody, reset my ecu and give her good 3 day period to see if it is gone or comes back.
Would my car run real rich or bad if I installed a Walboro 255 lph fuel pump? Imma search more just curious.
Old 11-12-2012, 03:05 AM   #14
David William
David William is an unknown quantity at this point
mystery fuel pump problem in my nissan patrol... help!!!!!!!!!
I guess its between coolant temp sensor or fuel pump problem... Check this two i guess you need to replace one of these..
One of the most vital component of your vehicle, the fuel pump, is a device used to pump the fuel from the fuel tank to the engine or fuel injection system.
My car nissan patrol stopped working thought problem was immobilizer so disconnected immobilizer system car was still not working and no fuel pump noise, so replaced fuel pump with new unit still no noise so checked fuel pump connection with test light and power was there thought there might be problem with fuel pump assembly, so connected to battery and fuel pump ran beautifully. Went to rear of vehicle again checked pump with test light once again power was there, connected fuel pump assembly and fuel pump once again not running. I have no idea what the problem is either does my brother he is across the state my brother thought it may be the body module after he suggested the other tests over the phone. Could any one possibly help me with this problem my brother is stumped and i am 17 and i cant afford to get an auto electrician........ can somebody help me..????????
GU nissan patrol
David William is offline   Reply With Quote
