Old 06-22-2004, 12:37 AM   #1
phrozen
phrozen is on a distinguished road
Send a message via AIM to phrozen
OBD-I and OBD-II Q's
Well i have a obd-i 91 240 in need of a new motor, and im looking to get a low milage motor from a s14 either 95obdi or 96+obd-ii. I have acess to a obd-ii 96 ka motor with like 40k and i was wondering if i can still run obd-i emissions and still pass ca smog with out throwing codes and stuff, ive heard that u can still run obd-i on a obd-ii ka just have to use all the obd-i emissions stuff. Im not trying to get a sr swap or anything just looking for a replacement and since i have acess to a 96ka i was wondering if id run into any problems with running obd-i. also i would be using s13 harness, distributor, ecu, lower and upper intake manifold, and exhaust manifold right? Ive been askign around and getting a lot of mixed responses. Hey var i hope u see this! i was gonna call u but i dotn have ur #
This box is 400x200:
Please do not put your sig pic back if it exceeds this.
-Moderation
phrozen is offline   Reply With Quote
Old 06-22-2004, 12:53 AM   #2
Ghst 01
Ghst 01 has a little shameless behavior in the past
Send a message via AIM to Ghst 01
well if u dont i might be interested in buying that 96 engine.... i want to start building up an engine on the side so i can swap it out later on and run more boost
AIM: ghst01
http://www.cardomain.com/ride/585615
http://www.myspace.com/8407376
96 red zenki:
Greddy KA Turbo kit (TD06-20g, 370cc, Emanage, Vspell FMIC), TEIN HE's, VIS Vader CF hood, Falken Azenis ST-115's, Sony Xplod head unit.
Ghst 01 is offline   Reply With Quote
Old 06-22-2004, 02:35 AM   #3
DuffMan
DuffMan's Avatar
I dont understand why people keep calling S13's OBDI they aren't. Have you ever seen a OBD port on a S13, anyone? There is just the Nissan Consult port. They arent OBD anything.
Only early 95 S14s were OBDI.
But to answer your question, yes it will work, just use S13 everything (ecu, harness sensors, intake mani)
Old 06-22-2004, 03:13 AM   #4
phrozen
hmm ok i guess that answers my question. i guess ill pick up that 96 motor and run all the s13 stuff. and hopefully it will pass ca smog and state ref
-Moderation
Old 06-22-2004, 10:35 AM   #5
Var
Var's Avatar
Send a message via AIM to Var
wassup jason.! the engine itself should work ok (i think) if you hook up the right sensors to it. otherwise it's a big piece of metal.
as far as s13 being OBDI..not sure but. ...they do have a diagnostic port. But it is not a universal one like OBDII
Hi
Old 06-22-2004, 02:33 PM   #6
phrozen
koo! well i actually found a coupe with a 95 motor with 75k, so i tihnk imma put the 95 in my fb and then put my 91 motor in the coupe after i rebuild it. Hope i can come up with the $
-Moderation
