![]() Join Date: Jun 2011
fpr tuning
ok so maybe ive been working to much idk but i feel retarded cause i dont remember how the hell to tune my circuit sport fpr someone gimme a hand i looked around couldnt find nothing. So let the hating begin haha please be gentle
zilvia.net/f/cars-sale/517359-95-240sx-sr20-swap-uras-greddy-apexi-ect.html |
thats what i mean lol i do that with the car off if i remember correctly lol but how i know how to adjust but the gauge reads 0 when i turn the car to on
![]() Join Date: Nov 2010
Mrgons, i will help.
Start the car, get it to normal operating temperature. Once warmed up WITH the car running, Disconnect the vacuum source to the FPR, but make sure the vac tube is plugged( Idle will fluctuate if its open). Adj the FPR by turning the adjustment screw until you reach ~43psi. reconnected vacuum tube, and psi should drop to ~36ish
thanks bro always there to save me when im retarded lol btw back in az on the 23rd of dec ill hit u up sometime
lol depends on mods ur running stock worked fine for me till recently
![]() Join Date: Jun 2007
Save it for when/if your current one craps on ya... Not a necessity- Plenty of 350-400hp SR20's running on stock regulators. It becomes a necessity beyond that, or when the person tuning your car says you need an adjustable; whichever comes first (usually the latter).
lol the car wasnt turned on the ignition was just turned to the on position shouldnt that kick the gauge on? the lines may be backward actually havent checked that
The gauge only reads presurre with the car running.
The gauge will move when the fuel pump primes, but mine goes back to zero after its done priming, with the engine off.
#14 | ||
![]() Join Date: Aug 2011
Even stranger, it seems to only happen to zilvian posters. Maybe because some fellows keep repeating that kind of BS when they actually dont have a clue ? |
#15 | |
![]() Join Date: Nov 2004
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
#16 |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
FPR goes on the return line from the fuel rail. So fuel rail to fpr then fpr to return line. Use the same vac source as the stock fpr. Fuel filter is on the feed line from tank so you dont mix them up. Prime it before starting it and get it in a reasonable range before starting the car. If its 0psi after priming then something isnt right.
#18 |
![]() Join Date: Jul 2005
I literally just tried to tune an S13 sr20det, and the OEM regulator gave up exactly around 330rwhp. The brand new Tomei 740cc injectors were open 95% duty cycle and it barely supported 330rwhp, air fuel was dropping to 15:1 by 7,200 rpm. Must be the air, yeah thats it, USA air causes it.
#21 | |
Nevertheless, not a part I would fail to replace on a 400 horsepower car, given the low cost and importance of. |
#22 | |
