Old 11-21-2012, 01:30 PM   #1
97nismo
97nismo's Avatar
Trader Rating: (53)
97nismo is an unknown quantity at this point
Feedback Score: 53 reviews
WTB: 95/96 J30 6 bolt vlsd...
I freakin cant find one anywhere.....need it shipped to 29678 or 30205
which ever is cheaper....i can meet meet north of atlanta
must go in my 98 s14 non abs
404-644-0927
call text pm...whatever just need one
brad
Feedback:
http://zilvia.net/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
Old 11-21-2012, 06:28 PM   #2
97nismo
97nismo's Avatar
Trader Rating: (53)
Bump.......
Feedback:
Old 11-21-2012, 07:26 PM   #3
r33silvia
r33silvia's Avatar
r33silvia is an unknown quantity at this point
pm and txt sent
r33silvia is offline   Reply With Quote
Old 11-21-2012, 08:35 PM   #4
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Brad, if you direct bolt up the J30 VLSD you will need an ABS driveshaft.
Old 11-21-2012, 10:38 PM   #5
ShadowDrifter
Trader Rating: (55)
ShadowDrifter is an unknown quantity at this point
Feedback Score: 55 reviews
you do not need the abs driveshaft there is less then half an inch difference either drive shaft will work, and yes I can prove this.
Drifters Do It Sideways
ShadowDrifter is offline   Reply With Quote
Old 11-21-2012, 10:39 PM   #6
ShadowDrifter
Trader Rating: (55)
but if your looking for a J30 diff I have one with 5bolt and axles too text me if you want it 570-241-2027
Old 11-21-2012, 11:14 PM   #7
KiLLeR2001
Trader Rating: (46)
Correction, if you want to half ass it, continue to use the improper driveshaft with a J30 VLSD. I'm sure Nissan made different driveshafts for no reason at all. Right?
S14:
Section 1: Coming From Trans (ABS makes no Diff. in Length here)
M/T = 421.0mm (16.57")
A/T = 441.0mm (17.37")
Section 2: Center Bearing/Mount to Diff
Non-ABS = 650.0mm (25.59")
ABS = 636.0mm (25.04")
Old 11-22-2012, 06:47 AM   #8
ShadowDrifter
Trader Rating: (55)
it works just fine i just took a j30 diff out of my 13 and had the stock manual DS in it with no problems at all for the last 2 years just becasue they have mesurements doesn't mean its always right im telling you I know for a FACT it works just fine
Old 11-22-2012, 03:01 PM   #9
ghoti
ghoti's Avatar
ghoti is an unknown quantity at this point
I don't thinks he is saying it won't "fit" of course it does. It will be a tight fit how do I know? Because I have done it, the thing is that you need the proper drive shaft since there has to be slack. Using the Non-ABS driveshaft can destroy the Transmissions rear mail seal and it will cause a leak.
So using a Non-ABS DS instead of ABS DS = Half-assing it
Originally Posted by SaNTi View Post
^ That shit always scares me... and I clinch my asshole a little bit.
ghoti is offline   Reply With Quote
Old 11-23-2012, 03:01 PM   #10
97nismo
97nismo's Avatar
Trader Rating: (53)
still looking
Feedback:
Old 12-10-2012, 10:36 AM   #11
97nismo
97nismo's Avatar
Trader Rating: (53)
still looking......bump
Feedback:
