Old 11-22-2012, 01:14 PM   #1
7Degrees
7Degrees is an unknown quantity at this point
s13 Anybody running a RS-Enthalpy ECU Tune for SR20DET?
Anybody running a RS-Enthalpy ECU Tune for SR20DET? Interested in your opinions on it. I am in the process of swapping a S13 SR20DET into my Lotus 7 kit car. My engine has ISIS stock replacement Turbo. I plan to run 550 injectors a Z32 MAF. Short of that everything will be pretty much stock save for a 3" down pipe and exhaust.
7Degrees is offline   Reply With Quote
Old 11-22-2012, 01:57 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
enthalpy, and rom tunes in general, are usually pretty ok, but not nearly as accurate as dyno tuning with a stand-alone. i've personally used a number of "reflashed" ecus (mines, central-20, etc) with excellent results, but the tune is usually a bit rich.
a reflash ecu, + wideband o2 sensor +s-afc will usually get you pretty solid results, but again, not as good as a full standalone.
Old 11-23-2012, 06:56 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
^^^This was exactly what i did with mine. Piggybacked SAFC to fine tune the fuel map. I was seeing 10s for my AFR under full boost on a GT2871R and 740cc injectors. Leaned it out some to 11s and got more gas mileage out of it.
CLICK HERE!!!
Old 11-23-2012, 09:22 AM   #4
ditchs14
ditchs14's Avatar
ditchs14 is a well-known jackass
yeah.im running one right now but on a KA....mine runs rich but its safe..i have a buddy that runs one on his SR but he lives in FL so martin tuned his on the dyno. he's a really nice guy. if you dont like the tune and you can log your afr's he can go off that and try to make it better
ditchs14 is offline   Reply With Quote
