Old 12-04-2012, 10:27 AM   #1
SilviaT
SilviaT is an unknown quantity at this point
SR Cutting out under boost after i cleaned n60 mafs
sr20det redtop rebuilt forged pistons, oem build. enthulapy tune pre mapped to n60 440cc injectors, headers full exhaust greddy rs bov recirculated internal wastegate t28 turbo.
SO i am missing the C clip to my n60 MAF and sometime when im driving ill notice my idle drop from 900 to about 600 and it will not rev past 2500/3000rpms like its in safe mode.. I get out, wiggle the connection to my MAF and it goes back to normal.. Drives great, pulls hard and idles steady until the connection gets messed up....
So everytime I would have to adjust the plug on the sensor, it would drive great after I made the connection solid.. So I let the car sit for a few days in the garage and thought about what I could do to fix it..
Cleaned my MAFS with MAFS cleaner.
Cleaned my filter with k&n cleaner kit.
Looked at the 4 wires going into the MAFS and made them all snug and tight in the plug.
Reset my ecu, now it's cutting out at boost!!!! Anything after 0psi under 3/4 throttle and it starts to cut out and studder/bog/ run like crap once its getting load....
WTF! It ran fine before, now it'd acting like its in limp mode and only getting code 55 on the ecu! It's an enthlapy tune btw. 440cc and n60 MAFS..
What should I do? Timing? Plugs? ( btw ngk iridium bkr7eix-11 gapped to .028 and at 1800rpm i can hear a buzzing noise coming from the top of my spark plugs and this only started happening after i re-gapped the plugs.) Suggestions pleaaaase!
SilviaT is offline   Reply With Quote
Old 12-04-2012, 02:36 PM   #2
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
when u cleaned ur maf did u remove the sensor itself from the housing ? did you touch it?
jdm213 is offline   Reply With Quote
Old 12-04-2012, 02:38 PM   #3
SilviaT
No I just cleaned it with the MAFS sensor cleaner I got at auto zone and did it the way they directed. I left the sensor itself inside the tube if that's what your asking
Old 12-04-2012, 07:17 PM   #4
SilviaT
It chokes out once i build up any boost at all.... Gonna clean my plugs and re gap them tomorrow. suggestions on gap???
ANYBODY have any info that might help me out??!...
Old 12-05-2012, 02:00 PM   #5
SilviaT
Helpppppp bumppppppp
Old 12-06-2012, 03:01 PM   #6
SilviaT
Gaping my plugs to .022 today. Going to check my wires going into my MAFS plug. (Maybe a bad ground wire) and will check timing with timing light.. Plugs were black and sorta smelt like gasoline..
Old 12-07-2012, 10:14 AM   #7
SilviaT
bbbbbbbump!!!
Old 12-07-2012, 12:49 PM   #8
thisisnotphil1
thisisnotphil1 is an unknown quantity at this point
Im having a similar problem with my rb. When i put a load on it, it runs stupid lean and it basically starves itself. What computer are you using? Ive heard about sr computers resetting themselves and basically forgetting the tune. Happened to a friend of mine.
thisisnotphil1 is offline   Reply With Quote
Old 12-07-2012, 12:54 PM   #9
thisisnotphil1
Im not too familiar about the sr or if thats a common problem but thats what happened
Old 12-07-2012, 01:08 PM   #10
SilviaT
Really? That's what it might be honestly.... I figured my maf might have taken a shit but maybe the ecu did reset itself! That's crazy.. It's a 62 enthulapy tuned ecu tuned in Florida for 440cc ad n60 MAFS.. This problem began once I cleaned my MAFS with crc cleaner. I was careful too
Old 12-07-2012, 02:26 PM   #11
thisisnotphil1
I would get another maf that you know works and try that before anything.
Old 12-07-2012, 03:18 PM   #12
ultimateirving
ultimateirving's Avatar
Its unlikely your ECU lost its tune.
Dude your symptoms point to boost/vacuum leak. Think about it, if it was a bad maf it would not be driveable, it would be very hesitant/boggy under any load.
Geta boost leak test and test everything from the maf back.
Z32 with lq4 swap
Old 12-07-2012, 03:50 PM   #13
nickauger
nickauger's Avatar
nickauger is an unknown quantity at this point
Try another maf , it is a very sensitive sensor.
nickauger is offline   Reply With Quote
Old 12-07-2012, 04:56 PM   #14
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
i have the same problem, somehow it fixed itself for now, it comes and goes, spark plug gaps are supposed to be for a sr is .28
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 12-18-2012, 12:46 PM   #15
SilviaT
Replaced mafs. Mafs is good now 100%.
Gapped plugs to .25 after a good solid cleaning.
Still getting boost cut/ choking/ studder after 1psi..
Since I was having mafs problems and code being thrown all the time, could that retard timing?
I need to check my timing next. That and fuel filter: pump
Idk what size pump I have.
Starts right up. Revs freely. Sounds healthy. Boost gauge is at -20 like it should be..
Any suggestions??
Old 12-18-2012, 12:50 PM   #16
SilviaT
Btw after I made sure mafs is good and did my plugs, went on a drive, came home and #1 plug was black again.. I do not have a a/f gauge. I know I'm running rich. I have a ACCEL DFI fuel pressure regulator (I think) and a fuel pressure gauge. Haven't checked the readings... Not getting boost an it makes me sad!!!
Old 12-18-2012, 01:58 PM   #17
ultimateirving
have you boost leak tested this yet noob. Actually get a tester made and boost leak test it. look at post #12.
your freaking falling on your face and running rich because at 1psi its leaking!
Z32 with lq4 swap
Old 12-18-2012, 02:23 PM   #18
SilviaT
No I haven't.
Even if my boost gauge says -20 I could have a leak? I already checked all my couplers but I don't have a tester. Will do though.
Old 12-18-2012, 02:27 PM   #19
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
-20 is vacuum. Boost is boost.
You probably have a coupler that's cut and not obvious.
I have a tester kicking around, but it's easy to make your own. Just need an air compressor.
Old 12-18-2012, 02:56 PM   #20
ultimateirving
Originally Posted by SilviaT View Post
No I haven't.
-20 is vacuum which means nothing is leaking out. when u hit boost something is opening/leaking and thats causing your issues. Once you hook up the boost leak tester pressurize the system and listen for loud hissing sounds of air escaping. and try to boost leak test at least to ur desired turbo psi.
Z32 with lq4 swap
