Old 12-11-2012, 11:19 PM   #1
89hatchman
89hatchman is an unknown quantity at this point
swapping KA24E out
for another KA24E. The current one is blown.
Just got the radiator and fan shroud out (without breaking anything!) and working on the harness and vacuum lines.
And holy shit the vacuum lines. There are more of them then I have ever seen in any other car. Should I be worried about getting them all back in the right place? Or do they all kind of bend back to their correct spot when I put everything back?
Any tips that you think I should know overall for this engine replacement?
89hatchman is offline   Reply With Quote
Old 12-12-2012, 01:28 AM   #2
iveexcaped3
iveexcaped3's Avatar
iveexcaped3 is an unknown quantity at this point
replace all of them..... just get the cut to lenth stuff from kragen or autozone so you dont have to worry about them being brittle or cracking and giving vacuum leaks..... also check you clutch (if stick) when you swap motors and regrease you throw out bearing and contact points for the fork.... ive done this swap 3 times so trust its worth checking
iveexcaped3 is offline   Reply With Quote
Old 12-12-2012, 07:37 AM   #3
89hatchman
Is it compliated getting all the lines back in their correct place?
Old 12-12-2012, 12:48 PM   #4
iveexcaped3
It's always easier doing them when the motor is out cuz its easy to access them
Old 12-12-2012, 04:59 PM   #5
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
If you don't have emissions testing, you may find it easier just to remove the lines entirely, along with other emissions accessories / parts.
Frank_Jaeger is offline   Reply With Quote
Old 12-12-2012, 05:37 PM   #6
edlover714
edlover714's Avatar
edlover714 is an unknown quantity at this point
if ur lucky hoses still have color coded lines on them write down on piece of paper wher each color line is in relation to tb vacum pipes and solenoids and on back of head replace each line one at a time so you dont get confused. if no color lines, an old trick is to mark each line with paint marker1,2,3ect and do same on location each hose goes1,2,3
edlover714 is offline   Reply With Quote
Old 12-13-2012, 10:13 PM   #7
iveexcaped3
if you screw up save this and blow it up, it helped me out serveral times diagram
Old 12-17-2012, 11:38 AM   #8
MamangSorbetero
MamangSorbetero's Avatar
MamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the rough
The Factory Service Manual: FSM has all the vaccuum routing you need. Go download a PDF ebook somewhere.
When you remove your old KA24E, its pretty basic: unbolt mounts, transmission bellhousing, catch can, cooling system, heater core hoses, EGR.
Just do the same for the other and it should just drop right in
MamangSorbetero is offline   Reply With Quote
Old 12-18-2012, 01:42 PM   #9
89hatchman
would you suggest separating the tranny from the block before pulling it out? Or just pull the whole thing out in one piece?
I just don't really want to struggle with the bolts on the top of the bellhousing...
Old 12-18-2012, 11:40 PM   #10
MamangSorbetero
The easy part is taking the engine out. The hard part is bolting it back on.
The right way to bolt the transmission back is to get the car on four stands and raise it up high. Then use a really long extender to torque them down from behind the bellhousing
Old 12-19-2012, 12:07 AM   #11
89hatchman
alright, forget that I'm going with pulling the tranny out as well.
Old 12-19-2012, 12:44 AM   #12
MamangSorbetero
You're still going to need to put the car on stands regardless. Trans sensors, hoses and mounts need to be unbolted. Driveshaft and components.
Imo, just pull the engine out and bolt it back ghetto way. Take it to a shop lifter to finalize the torque settings lol. It's hard being a garage king
Old 12-23-2012, 10:36 AM   #13
iveexcaped3
6x easier pulling it with the trans. Issue is you need to drain your gear oil cuz it'll all pour out the tail shaft and end up on your floor.
