Old 12-27-2012, 10:55 PM   #1
dbiz
dbiz is an unknown quantity at this point
Clutch Slave Keeps Leaking, I Keep Replacing.
UPDATE
So i replaced everything because my old master was leaking as well. So new master cylinder, steel clutch line, and a brand new nismo slave. Bled out all the air and topped out the master. Start my car all happy put clutch in and put it in first (almost had to force it in) look back and the wheels were spinnin. Thank god i was still on the lift or i would ended up in a wall lmfao. Anyone have any clue wtf is happening now?
The clutch stopped engaging after i installed the nismo slave. i bled it all morning today with no difference. Anyone know if the sr/ka nismo works with an rb20? Bolted right up yet my cheap napa slave was engaging the clutch better. Also imnot getting much pressure when bleeding from the slave.
dbiz is offline   Reply With Quote
Old 12-28-2012, 12:57 AM   #2
retrograde.
retrograde. is an unknown quantity at this point
where is it leaking from?
retrograde. is offline   Reply With Quote
Old 12-28-2012, 08:23 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You're probably hyper-extending them out. Take the slave cylinder pin out, find something to replace it with that is slightly longer. I've used bolts before when I was having something like this happen on my SR a while back.
CLICK HERE!!!
Old 12-28-2012, 11:00 AM   #4
240knockout
240knockout's Avatar
240knockout is an unknown quantity at this point
Are you using OEM clutch line or aftermarkter stainless steel replacement? I bought one of these a while back that would always leak at the threads.
240knockout is offline   Reply With Quote
Old 12-29-2012, 06:04 PM   #5
dbiz
ill take a look when I can get to my school shop and see what I can do.
the little boots on the slave
oem for now.
Old 12-29-2012, 08:30 PM   #6
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
Are you using a heavier than stock pressure plate or constantly clutch kicking? It sounds like the cylinder seals can't handle the stress being put on them. I bought my 240 with a Nismo slave already installed on the RB25 transmission. It's been going strong even with the increased strain of a HD clutch pressure plate. Several months ago, while driving, my clutch pedal went flat. I got out, looked under my car, saw the clutch fork hanging funny (I had broken the fork pivot ball), and my slave cylinder pin was overextended to the point where it was being held on by only the slave boot. My transmission shop didn't believe the slave cylinder could still be used but I refused to buy a new one. I got the pivot ball replaced, pushed the slave cylinder pin back in, bled the clutch line, and it's been working flawlessly ever since. Nismo slaves might be kinda $$$ but they seem to be bulletproof. Try thenismoshop.com. According to their website, the RB20 uses the same cylinder as the RB25??? I've always thought the RB20 used a smaller cylinder. Might have to check the RB FAQs on that one.
dbeiler is offline   Reply With Quote
Old 12-29-2012, 08:40 PM   #7
dbeiler
dbeiler's Avatar
Oops, my bad. The 4wd Skyline RB20 uses the same as the RB25. I'm not sure Nismo makes one for the 2wd RB20 transmission.
Old 12-29-2012, 09:05 PM   #8
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
NAPA ones suck. I had to buy 3 in a row to get one that worked, and it is sorta weak.
When it comes to slave cylinders, Nismo or OEM are worth the etra money.
Seraphim38 is offline   Reply With Quote
Old 12-29-2012, 09:08 PM   #9
dbiz
Holy shit thank you! I do have a HD clutch so the seals likely can't handle it. Other than that it's all gucci until i start kickin the clutch. And just checked the nismoshop and it seems they dont have one for the rwd tranny. I know nismo did make them though, so I'll keep searching. Thanks bro I will update with results when I upgrade.
Old 12-30-2012, 08:47 AM   #10
fliprayzin240sx
Come to think of it, I think I got a Nismo Slave cylinder that i was using on my old SR. If you're looking for one, lemme know.
CLICK HERE!!!
Old 12-30-2012, 12:07 PM   #11
dbiz
Pm'd youuuu
Old 01-28-2013, 02:09 PM   #12
dbiz
So i replaced everything because my old master was leaking as well. So knew master cylinder, steel clutch line, and a brand new nismo slave. Bled out all the air and topped out the master. Start my car all happy put clutch in and put it in first (almost had to force it in) look back and the wheels were spinnin. Thank god i was still on the lift or i would ended up in a wall lmfao. Anyone have any clue wtf is happening now?
Old 01-28-2013, 02:28 PM   #13
dkim1985
dkim1985's Avatar
Trader Rating: (28)
dkim1985 is an unknown quantity at this point
Feedback Score: 28 reviews
i know you have an rb20 but..are you still using your clutch dampener?
i was having a problem with that, ended up just removing it.
btw, i have a slave cylinder for sale if you're interested later on.
FS: Nismo R-Tune Camshafts for VQ35DE.
dkim1985 is offline   Reply With Quote
Old 01-28-2013, 03:22 PM   #14
!!chuy!!
!!chuy!!'s Avatar
!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore
i got rb25 with rb20 tranny.
my old csc would leak all my fluid and i would constantly loose clutch pressure, so i replaced it with the autozone one. i went to the local autozone and picked up a normal s13 clutch slave cylinder (15 bucks) and it bolted up just fine. bled it and a few days ago went to PARC drifting event and clutch kicked all day and held up fine...
!!chuy!! is offline   Reply With Quote
Old 01-28-2013, 03:34 PM   #15
dbeiler
dbeiler's Avatar
Sounds like it hasn't been bled properly. Was the new master cylinder bench bled before it was installed? The clutch line dampener (if you still have it) takes a lot of fluid and can be difficult to bleed. Keep bleeding the crap out of the cylinder, clutch line, and dampener. It'll work.
Old 01-28-2013, 05:33 PM   #16
dbiz
Im going straight from the master to the slave. No damper. Also i'm not getting any more air bubbles although i did not bench bleed it. I'll try to keep bleeding it to see if i can make a difference.
Old 01-28-2013, 07:20 PM   #17
dbeiler
dbeiler's Avatar
I've never bench bled the master (never replaced a master cylinder) but I hear say it's a very important part of the bleeding process. With no dampener installed and no air bubbles left in the line, I would assume the master cylinder not being bench bled is the problem.
Old 01-28-2013, 07:49 PM   #18
dbiz
problem is ive only seen bench bleeding done with two lines going in and out of the master. my master only has one line. anyone know or have experiences with bench bleeding s13 master cylinders?
also my clutch pedal does have regular pedal feel in it but i think there still might be some air in the system not letting the slave to push the fork in all the way.
Old 01-28-2013, 08:16 PM   #19
dbiz
also:
i originally JUST replaced the slave cylinder with a nismo one and had this same exact problem. the clutch wasnt completely engaging. thats why i just replaced the CMC because it had horrible sludge and i assumed that it was simply air not letting me engage the clutch. even with a leaking slave cylinder it was engaging 10 times better than with my brand new nismo slave. any reason as to why the nismo slave would not push the clutch fork all the way?
Old 01-29-2013, 06:59 AM   #20
dbiz
Just bled the piss outta it and the clutch is still not engaging. It seems my slave isnt pushing the fork out all the way. Anyone ever have a problem with a nismo slave on a rb20?
