Old 06-02-2012, 12:59 PM   #1
247_c2c
247_c2c is an unknown quantity at this point
Rb20det help!!!! MAF N60 or n62
Hey everyone my rb20 runs kool just wants to die out when coming to a stop Ive been told its my MAF currently running a n60 would and n62 MAF work?? Please any help to solve this issue would be MUCH appreciated!! Thanks
Update!!! I got her to stay on at idle now it wasn't the maf like the guy said smh but I fixed a lot of boost leaks and now she stays on but now I have to adjust the timing because it's way to advanced! Thanks for everyone's help! It's been very help
Now if you have an rb20 oil pan that's in good condition let me know I need one lol
247_c2c is offline   Reply With Quote
Old 06-02-2012, 11:55 PM   #2
247_c2c
Originally Posted by huohuli11 View Post
thumbs up Good luck!
Thanks just want to drive her without having to try and keep her on at every stop :/
Old 06-02-2012, 11:59 PM   #3
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
Do you have the blow off valve dumping back into the intake or did you ricer it out by letting it dump into the atmosphere?
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 06-03-2012, 12:03 AM   #4
247_c2c
Lol have it going into the intake
Old 06-03-2012, 12:50 AM   #5
Yellow4g63
Check for a vacuum leak, a broken hose or lose intercooler piping clamp. How many inches do you pull at idle? 15? 20? on the boost gauge.
91 Nx2000 VVL yo
Old 06-03-2012, 01:08 AM   #6
Jhester
Jhester's Avatar
Jhester is an unknown quantity at this point
Send a message via AIM to Jhester Send a message via Yahoo to Jhester
Recirc !
Jhester is offline   Reply With Quote
Old 06-03-2012, 06:35 AM   #7
247_c2c
Ok ill have to look around, It's pulling 15 at idle
Old 06-03-2012, 10:35 AM   #8
Yellow4g63
Yeah you should be at least 19-20. You can build a tester at home depo. Google it and you will see what you need. Make sure to disconnect the PCV from the intake manifold to the valve cover when you do and don't put more than 5-8psi into the system.
91 Nx2000 VVL yo
Old 06-03-2012, 10:38 AM   #9
Sileighty_85
Sileighty_85's Avatar
If your ECU is stock and not running a SAFC thats setup for those MAFS then you are using the wrong one.
Stock RB20 MAFS are J60's
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-03-2012, 10:55 AM   #10
Yellow4g63
You can run the N60 maxima maf in place of the stock. The VQ maps are dead on with the factory maf. I think the S2 RB25 uses the E60 pink label one. Even that one is pretty close too lol.
91 Nx2000 VVL yo
Old 06-03-2012, 02:14 PM   #11
Sileighty_85
Anyone got proof? voltage checks?
I just dont believe Nissan would would develope Two MAFS that produce the same Voltages just to use a diff connector.
後輪駆動車1番
1986 SR86 - 200ish
Old 06-03-2012, 02:31 PM   #12
247_c2c
I am running stock ecu, Do you know where I can get a j60? Lol haven't seen one on here
I've heard the n60 would work to? That's what's one there now
Old 06-03-2012, 04:20 PM   #13
Sileighty_85
Theres some on Ebay
search under "j60 skyline air flow"
後輪駆動車1番
1986 SR86 - 200ish
Old 06-03-2012, 04:32 PM   #14
Yellow4g63
You can search on Nico in the RB section it's well known. Also I changed the rom on another car I tuned to run the RB20 maf. I bought the N60 maf and plugged it in and didn't have to change the VQ map at all. It fired right up and got the same A/F reading as before.
91 Nx2000 VVL yo
Old 06-03-2012, 09:09 PM   #15
247_c2c
Update I just found two kinked hoses and when I unkinked it the car idled high and then went to normal so in thinking its not getting the proper air flow when coming to a stop
Old 09-30-2012, 08:52 AM   #16
bigheadJswag
bigheadJswag's Avatar
bigheadJswag is an unknown quantity at this point
I have a similar problem too man.. PLease kepe us updated and about the rb20 maf as well, if you ever get one let us know is it has positive effects..Thanks many
EDIT: Sorry, but anyone know where you can find the connector/pigtail for the rb20 stock maf?
bigheadJswag is offline   Reply With Quote
Old 09-30-2012, 09:31 AM   #17
247_c2c
Well I don't have the rb anymore but I did end up fixing the problem... The previous owner did a shitty job with the swap and had a almost every vacuum line leaking so I stopped the leaks and it fixes the problem
Old 09-30-2012, 09:39 AM   #18
bigheadJswag
Dam,alright thanks alot tho.
Old 12-30-2012, 03:37 PM   #19
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Air Flow Meters..
