![]() Join Date: Jun 2010
Trader Rating: (22)
![]() Feedback Score: 22 reviews
Overheating at high rpms or high speed only
Raidiator bubbles :/ - YouTube
Only overheating at high RPMS and or High Speed Thermostat was removed because i thought it was possibly stuck closed fan clutch is working properly (or so I think?) no signs of leaks -.- I provided a video that i uploaded to YouTube showing tiny air bubbles every time i give the engine gas... I'm thinking possible head gasket? Not sure tho, There is no coolant in the oil or oil in the coolant and no white smoke coming from the tail pipe |
#3 | |
Also bubbles could be that the water is boiling in the block or head .. This too is very bad if air gets stuck in the block as it will create hot spots and I have seen engines lost to this as well ... I recommend running Evans NRG+ if you can afford it.. It will not boil tell 375* and it doesn't expand .. You can also run a ZERO or LOW pressure cap and it will be easier on all your coolant lines as well .. 1. Replace TSTAT 2. Evans NRG+ Coolants ยป Engine Cooling Systems 3. Optional - Low or Zero pressure cap .. Hope that helps .. |
![]() Join Date: Sep 2006
![]() Feedback Score: 23 reviews
higher rpms/speeds = more rpms = more explosions = more heat.
step up your cooling system. (your probably knew this.. maybe the next person doesnt?) also, something else i recently learned about, (in regards to you removing the thermostat that acts as a restrictor) is cavitation damage to front cover, water pump, etc.)
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
Get a thermostat , cooling requires time!
Bubbles , you either have air in your cooling system or headgasket problem , feeding back crankcase pressure into cooling system. Start the car cold with the rad cap off get up to operatiing temp, holding throttle around 3k rpm , once your thermostat opens you should get a flow , throttle the engine and watch for bubbles , burp the cooling system of air you should have a bleeder screw on the neck 10m open it wait for fluid and tighten. Let cool down remove rad cap ,start car hold throttle at around 2.5 rpm and if you get bubbles you have Mild HG problem that could blow a rad , hoses and more. |
something else that could effect it are pinholes in your cooling system, they will draw air into your cooling system (wont leak) and sr absolutely hate air in the system, it happend to me before....
#9 | |
Like Me on FaceBook ![]() |
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
It might be a long shot but with the thermostat out, the cooling system is flowing too freely, and every-time your at high engine speeds the water pump could be cavitating causing air to separate from the coolant and appear in the system.
#18 |
![]() Join Date: Jul 2005
you can also get bubbles if the coolant is contaminated with power steering fluid or any number of other car related fluids.
Pressure the coolant system with the engine off and check for leaks. A leak can let water out, or air in. Do NOT flip out and automatically assume the headgasket is toast. And, I see metal end tanks. Is that a KA radiator? |
