Old 12-31-2012, 04:12 PM   #1
ke70 sr20det
ke70 sr20det is an unknown quantity at this point
SR redtop aem ems2 problems fuel issue
hi
my freind recently installed the ems2 and it dint started up, because of wiring issues. so now he took all the wiring out and started with new. now everything is set back again and its connecting but again its giving issues when we try to start up the car it goes into waiting then again connect. we are using aem base calibration file and everything thing is going oki except it gives very low or no pulse in injectors, wires are seem to be ok and tested the injectors they are fine ..
setup
370cc
gt28r s15
3.5bar sensor
iat
can someone tell how to fix these problems or how to set the settings ...................
i tried on aem forums no help so far ...i need this this thing get running
help is appreciated
ke70 corolla sr20det redtop t28 s15 7 psi stock motor
ke70 sr20det is offline   Reply With Quote
Old 12-31-2012, 04:15 PM   #2
ke70 sr20det
from the frist two graph while cranking it shows this
on the third graph what ever we do the injectors are not coming on
Old 12-31-2012, 05:06 PM   #3
OutToWinPAHC
OutToWinPAHC's Avatar
OutToWinPAHC is an unknown quantity at this point
Send a message via AIM to OutToWinPAHC
is the ECU loosing power when in cranking position, sounds like it.
OutToWinPAHC is offline   Reply With Quote
Old 12-31-2012, 05:31 PM   #4
ke70 sr20det
yes ecus coonects ...while cranking ecu waiting then again connects and injectors are not spraying at alll
Old 01-01-2013, 12:54 AM   #5
OutToWinPAHC
fix the ecu power issue first, mainly eccs
Old 01-02-2013, 05:28 AM   #6
ke70 sr20det
The ecu connection problem is fixed, it was the battery issue, now i have a stable connection, but still the car wont start, i have hooked up a led strip on the injector wiring to see pulse but there is no pulse, the car is cranking and everything but so far no luck
Old 01-02-2013, 08:21 AM   #7
OutToWinPAHC
I would double check that tiring, with a meter to one side of the fuel injectors you will have positive voltage, the ECU actives them by switching the gounds, so look for power to the injectors and did you do all the pin changes and trigger wheel disk?
Old 01-02-2013, 10:00 PM   #8
ke70 sr20det
yes, i have done all teh changes and installed the trigger disk, see if i manually put gas from the intake mani, the car starts, but since the injectors are not on, the car shuts down. i will double check the injector wiring, am i not calibrating it corectly or what ?:S
Old 01-03-2013, 09:46 AM   #9
OutToWinPAHC
I had some issues with mine at first because the wiring table was not super cut and dry and I lost a 5V signal voltage. When you did your TPS wizard it goes from .4 to about 4.8VDC on the screen? In the injector table are the injectors turned on? Send me the map file your using and I will check it out
Old 01-03-2013, 10:12 AM   #10
Jason@psi
Jason@psi is an unknown quantity at this point
edited PM'd
Jason@psi is offline   Reply With Quote
