Old 01-01-2013, 12:40 PM   #1
streetprototype
streetprototype's Avatar
streetprototype is an unknown quantity at this point
need help installing boost gauge s14sr
So I've done quite a bit of reading. some say best way is to tee it off from the fpr vacuum Line, and some say its bad. Can someone enlighten me on how to install this. Btw its a mechanical boost gauge. Thanks guys
streetprototype is offline   Reply With Quote
Old 01-01-2013, 02:52 PM   #2
cotbu
cotbu's Avatar
I think your post is stupid considering the subject has been covered a bajillion times.
scenario 1: right now fpr vacuum not t'd. How would you know if you developed a leak at the fpr?
scenario 2: fpr t'd with boost gauge. You know have a monitoring system installed. Not only for boost, it monitors the vacuum and boost to the fpr.
Tap, T or not to T is purely an opinion nothing else, use your big boy or girl decision making skills! It's 2013 wake up!
The short version!
Old 01-04-2013, 04:13 PM   #3
itz matthew xP
Location: NYC if i tell you anymore i will need to kill you!
itz matthew xP is an unknown quantity at this point
It has been covered so many times but none has a definite answer. I have the same problem also, some say T off the FPR and some say to T off the vacumm hose to the wastegate. I would like to know also. And yes i searched all over the forum including nico, 240sxforum, etc. the post starts out good then it is a bullshit people flaming and get side tracked on the subject.
itz matthew xP is offline   Reply With Quote
Old 01-04-2013, 04:25 PM   #4
Jez
Jez's Avatar
Jez is an unknown quantity at this point
I have mine T'd off the W/G vac hose, from what I have read and been told by the shop that tuned my car, the FPR vac lines should not be T'd for any reason.
This from what I understand is to ensure the FPR gets correct signal to do its job, without having to supply a boost gauge also.
Jez is offline   Reply With Quote
Old 01-04-2013, 04:49 PM   #5
cotbu
cotbu's Avatar
That is what we call false information!
You have to be trusted, by the people that you lie to
The factory routing has the FPR T'd, sooooo i suggest running a boost gauge to the fuel pressure regulator for all the reason people say don't! That is if there's a leak you'd know it. Otherwise how would you?
BTW the wastegate doesn't need vacuum to work soooo! you probably have you wastegate hooked up wrong also!
Old 01-04-2013, 05:20 PM   #6
Jez
Jez's Avatar
Originally Posted by cotbu View Post
That is what we call false information! The factory routing has the FPR T'd, sooooo i suggest running a boost gauge to the fuel pressure regulator for all the reason people say don't! That is if there's a leak you'd know it. Otherwise how would you?
My mistake mine is T'd off the BOV
"Tap, T or not to T is purely an opinion nothing else, use your big boy or girl decision making skills"......no big deal then right? Opinion and personal preference?!?
"You have to be trusted, by the people that you lie to "
Not a Pink Floyd fan then?
Old 01-04-2013, 05:49 PM   #7
itz matthew xP
So it is definite to T off the FPR. Thanks i have mines running off of my FPR, alsoi wanted to know, my boost controller set at stock setting but when i'm at full throttle the gauge reads 5 psi. Does this mean i have a leak somewhere?
Old 01-04-2013, 08:09 PM   #8
cotbu
cotbu's Avatar
I was using that quote, of yours to give you an idea, about the information you've been given!
Here's another:
I gotta admit that I'm a little bit confused.
Sometimes it seems to me as if I'm just being used.
Gotta stay awake, gotta try and shake off this creeping malaise.
If I don't stand my own ground, how can I find my way out of this
maze?
