![]() I did the 300ZX brake swap in the front and the back and the only real problem that I've run into is the parking brake cable. I followed the install that was detailed in the Sport Compact Car magazine and they left alot of important information out,
![]() ![]() Does anyone know of a company or anyone who makes custom parking brake cables for this swap? Or does anyone know of anyplace that I could get to fabricate me up some decent looking parking brake cables? I can live with what I got for now but I'm just not really diggin the Getto Fabulous look. Thanks in Advance |
hey man, not sure how it works.. i have a 300z brake setup 30mm all the way around. i have an s13, but the guy who installed them documented EVERYTHING perfectly. i have pics if you want them, sorry im not of too much help.. but it will show u exactly what has been done to the car. my aim name is anubiswh, but im not on there often. email me at [email protected] if u want them
~Sunrise |
![]() Join Date: Sep 2002
I have an S13 and have Z brakes all around as well. I ran it through the subframe like SCC did and I had no problems. I did have to dremel a lot of the metal fittings off the Z cables because it would not fit between the subframe and gas tank like you mentioned. I also use some of the brackets the from 240 cable to secure the Z cables. I dont have any pictures but I need to change the oil so if you need me to I could take pictured while Im doing that.
Also I did look into making my own cables and found it to be difficult to find a good supplier for push pull cable that was willing to work with me. Since I was buying much cable they really didnt want to talk to me at all. I also could not find anyone locally which was what I really wanted. I had both cables uncut and wanted to walk in and say I need this cable with this ends and here is what Im talking about. Good luck in your search I finally gave up and took the SCC way. If your worried about the cables coming apart. Id suggest going to a shop and having someone put some welds on your cable to hold them in place. May not be neat and look nice but it should work fine. |
