Old 01-12-2013, 05:34 PM   #1
TrooyyS14
TrooyyS14 is an unknown quantity at this point
S14 diff swap/ Drive shaft bolts not coming off
The drive shaft bolts(4) Connected to the diff do not want to come off. I'm pretty strong. I've PB blasted them and still they wont budge. The drive shafft keeps moving and i feel like im going to strip the shit out of them.!I need help fast
TrooyyS14 is offline   Reply With Quote
Old 01-12-2013, 05:42 PM   #2
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Put the car in gear? Lol
Old 01-12-2013, 05:43 PM   #3
TrooyyS14
It's in gear and ebrake is on.
Old 01-13-2013, 01:53 AM   #4
MtnGoat
MtnGoat is an unknown quantity at this point
I had the same problem while dropping my diff a couple months ago. I put the wrench on the bolt and whacked it with a hammer. It was loose by the 2nd impact. Didnt even have it in gear or have the Ebrake up.
MtnGoat is offline   Reply With Quote
Old 01-13-2013, 05:49 AM   #5
jr_ss
Use the box end of the wrench and tap it in the correct direction with a hammer. They'll break loose eventually.
-Edit-
Now that I think about it, you need to be using two 13mm wrenches if I'm not mistaken. The nut will not spin on the diff side because of the pinion flange. You need to be loosening the bolt on the driveshaft side of the flange.
Old 01-13-2013, 06:25 AM   #6
The Dude
The Dude's Avatar
The Dude is an unknown quantity at this point
I eventually broke down and used an angle grinder/dremel.
The Dude is offline   Reply With Quote
Old 01-14-2013, 08:53 PM   #7
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
If you have a small propane torch you can use that too to potentially help out. Try to heat the nut and it will help things expand. Put your 14mm wrench over the nut, and then use the two wrench trick. Should come right off.
2 wrench trick:
Old 01-14-2013, 09:28 PM   #8
TrooyyS14
Yeah I got it yesterday. I used the two wrech. My main problem was I was alone and driveshaft kept spinning
Old 01-14-2013, 10:42 PM   #9
codyace
codyace's Avatar
Trader Rating: (58)
For someone reading this in the future upon searching, you can always take a long screw driver/bar/whatever and jam it through the U joints and let it 'jam' against the body to help remove them too. I always do that as I'm too lazy to get back out from under the car to release the e brake to spin the shaft over to get to the opposite bolts (same trick used when taking the CV axles out).
Old 01-15-2013, 01:52 PM   #10
ghoti
ghoti's Avatar
ghoti is an unknown quantity at this point
I do that screw driver/bar trick in the junkyard also.
Except that I would put the screwdriver on the "vents" of the rotors (if they had any) and they would jam against the caliper.
Originally Posted by SaNTi View Post
^ That shit always scares me... and I clinch my asshole a little bit.
ghoti is offline   Reply With Quote
Old 01-16-2013, 02:02 PM   #11
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I usually stick a pry bay between the U-joints if I'm too lazy to keep crawling under the car to pull/drop the Ebrake.
CLICK HERE!!!
Old 01-17-2013, 12:58 AM   #12
Paint209
Paint209 is an unknown quantity at this point
yea, i swapped out my diff last week and managed to get 3 of the 4 bolts off using this>>>
Then...
lol. was using new bolts anyway and i cut it from the diff side so all was ok.
Paint209 is offline   Reply With Quote
Old 02-12-2013, 02:14 PM   #13
s14sliding
s14sliding is an unknown quantity at this point
had the same problem today as im having same problem with tranny plug. these bolts are tough ill def have to try 2wrench trick for my drive shaft tomorrow. any advice for the tranny plug though? that thing wont budge
s14sliding is offline   Reply With Quote
