Old 01-13-2013, 12:23 PM   #1
Mrpopo
Mrpopo's Avatar
Mrpopo is an unknown quantity at this point
Sr20det black top part out
Ok screw it, I'm parting my extra SR out instead of rebuilding it. Prices are OBO. Pm for quickest response. Thanks
-52f block. Needs deck and cylinder hone. Crank girdle included. $150 no shipping on block
-intake manifold w/ throttle body and IACV with harness. No injectors or rail. $100 shipped
-crankshaft in great condition. Measures in oem numbers all the way across. $200 shipped
-used oil pump. Spins freely. $25 shipped
-timing chain guides $25 shipped
-oem cams with gears $75 shipped
-oem oil catch cans x2 $20 shipped each
-full set of oem rods in great condition. Pistons are attached but only 3 of the pistons are good. $165 shipped
-full set of oem rods w/ pistons. Pistons are good but 1 rod needs polishing. $165 shipped
-intake pipe from tb to intercooler $40 shipped
-IACV valve in great condition $70 shipped
-layered exhaust manifold gasket $15 shipped each
-engine mount brackets pair $45 shipped
-oem recirculating valve $30 shipped
-valve cover garnish scuffed $25 shipped
-timing chain tensioner used SOLD!
-upper oil pan $45 shipped
-lower oil pan scuffed $25 shipped
-rear main seal housing $25 shipped
-water pipes under intake $35 shipped
-oem oil pick up x2 $20 shipped each
-s13 tranny cross member with mount $40 shipped
-blacktop harness for s13 chassis. Good condition $125 shipped
-alternator bracket $30 shipped
-ka24de maf from a 95 $45 shipped
Mrpopo is offline   Reply With Quote
Old 01-13-2013, 01:57 PM   #2
jspec
jspec is an unknown quantity at this point
Interested in alternator bracket. Also need the the belt adjustment bolts for the bracket. Does it come with the bracket. Need asap thanx.
jspec is offline   Reply With Quote
Old 01-13-2013, 02:34 PM   #3
Tkoppab
Tkoppab's Avatar
Trader Rating: (22)
Tkoppab is an unknown quantity at this point
Feedback Score: 22 reviews
Interested in your timing chain tensioner
Tkoppab is offline   Reply With Quote
Old 01-14-2013, 05:55 AM   #4
jspec
Any luck on those atlternator belt adjustment bolts?
Old 01-14-2013, 06:07 AM   #5
Mrpopo
Mrpopo's Avatar
I found the long one but not the short one with the little sliding plate I don't have.
Old 01-15-2013, 11:50 AM   #6
Mrpopo
Mrpopo's Avatar
Second bump
Couple sales have not been closed yet so everything is still available
Old 01-16-2013, 06:14 AM   #7
Mrpopo
Mrpopo's Avatar
Third bump
Old 01-16-2013, 11:23 PM   #8
Meeekzz
Meeekzz is an unknown quantity at this point
pm sent...
Meeekzz is offline   Reply With Quote
Old 01-17-2013, 05:59 AM   #9
Mrpopo
Mrpopo's Avatar
/\ replied
Old 01-17-2013, 06:11 AM   #10
ersus
ersus's Avatar
ersus is an unknown quantity at this point
Send a message via MSN to ersus
do you have the CAS???
ersus is offline   Reply With Quote
Old 01-17-2013, 06:12 AM   #11
Mrpopo
Mrpopo's Avatar
I do not, sorry
Old 03-22-2013, 07:48 PM   #12
Jumpman12224
Jumpman12224 is an unknown quantity at this point
Do you still have crankshaft very interested
Jumpman12224 is offline   Reply With Quote
