Old 01-26-2013, 07:06 PM   #1
wurley
wurley's Avatar
wurley is an unknown quantity at this point
Running on three cylinders, no signal to #1. Need help
I have a ca18det swapped hatch, it ran good until the wiring from the previews owner started to fall apart at which point i decided to get all new wiring from wiring specialties.
So i replaced the lower and upper harness and have everything back together but coilpack #1 isn't getting the signal to fire.
I used a test light to check the coilpack harness and it was good, so what could it be? ignitor? ecu?
My ecu is thowing code 21 "Ignition signal fault"
wurley is offline   Reply With Quote
Old 01-26-2013, 07:14 PM   #2
S14_BOSS
S14_BOSS's Avatar
S14_BOSS is an unknown quantity at this point
Make sure that it is properly connected to the coil. Mine for some odd reason came loose once when i was on the freeway! Sounded like a suby.
S14_BOSS is offline   Reply With Quote
Old 01-26-2013, 08:02 PM   #3
wurley
wurley's Avatar
i thought the problem was a bad connection, but the test light shows the signal wire isn't doing anything on #1. I don't see how this could happen on only one cylinder unless its a wiring problem, but like i said my wiring is all new.
Old 01-26-2013, 09:04 PM   #4
S14_BOSS
S14_BOSS's Avatar
I would then test for continuity on that wire. Could possibly be there is a break somewhere in the wiring. Also wouldn't hurt to open up the ECU and have a look at the board to make sure there are no burn marks or blown capacitors near the pin related to #1 coil.
Old 01-26-2013, 09:32 PM   #5
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
find a coil wiring diagram and trace the wires for the coil that is not firing. then check to make sure yours are connected to where they are supposed to go by doing a continuity test. if i am not mistaken, this is a waste spark ignition system so coil one and four, and coil two and three should be parallel wired. if so, coil one should have the same wires as coil four. but, i could be wrong.
rcdad123 is offline   Reply With Quote
Old 01-27-2013, 01:43 PM   #6
wurley
wurley's Avatar
i checked all the wiring from coil to ignitor and its all good
does anyone know how i would check to if the ignitor is getting power?
Old 01-27-2013, 06:40 PM   #7
wurley
wurley's Avatar
got it fixed, turns out the ecu and connector weren't making a good connection. Thanks for the help guys.
