Old 07-03-2011, 07:04 PM   #1
EnemyS15
EnemyS15 is an unknown quantity at this point
Wiring gurus, I need your help!
I am using a S14 (95) Jdm Chassis and Dash harness on my 95 USDM RHD conversion. I am retaining the USDM upper and lower engine harness. I have almost everything wired up and I have a couple of problems that I hope you guys can help me with.
1: Jdm Wiper motor is constantly running, regardless of what wiper speed I set it on (jdm wiper switches). Thought about taking out the internals from my Usdm wiper motor and installing them into the Jdm wiper motor.
2: When I use the turn signals (Jdm switches), the side bumper markers work, but the corner turn signals don't work. (everything should be plug and play, to my knowledge, but I seem to have this problem)
3: I am using the USDM rear chassis harness. I know the JDM dash harness pins do not line up with the USDM rear chassis harness. I am wanting to find out what JDM pins corralate with the USDM rear chassis pins, so I can repin them in the correct place. (When I plug in rear chassis harness into the dash harness, obviously nothing lights up. When I switch the turn signal to the left, I hear the antennae motor turn on)
Thanks
EnemyS15 is offline   Reply With Quote
Old 07-03-2011, 07:25 PM   #2
junn
junn's Avatar
junn is an unknown quantity at this point
Gsxrjordan should know what's wrong
junn is offline   Reply With Quote
Old 07-04-2011, 11:17 AM   #3
EnemyS15
Says his name is not found when I go to pm him.....
Old 07-14-2011, 05:58 AM   #4
EnemyS15
Better explination with pics.....
Shows the rear USDM harness connector along with 2 gray connectors (right of the connector). What do those 2 gray wires run to Anyone know what color cables coincides with what on that connector?one has black tape around and the other has yellow tape
2nd pic is the JDM SMJ from the main harness. Anyone know what color cables cooincide with what on that harness connector?
3rd is the USDM rear harness and the cables. If you notice the USDM harness has more cables than the JDM harness. I am trying to figure out what goes to what so i can match em up and call it a day.
Anyone that can either
provide me with the info to repin the USDM harness to match the JDM harness
OR
Has the knowledge to do this for me
I Would greatly appreciate it!
Thanks
Old 07-14-2011, 06:10 AM   #5
bb4_96
bb4_96 is an unknown quantity at this point
here is the link to access the FSM's on nico.
Index of /FSM
Sounds like all you need is to look at the wiper circuit for s14 240sx and s14 silvia. It will show the SMJ pins in the circuit. It will also label the SMJ pins on the flyout for the SMJ.
bb4_96 is offline   Reply With Quote
Old 07-14-2011, 12:57 PM   #6
EnemyS15
these fsm's are greek to me. I am not gonna even pretend to comprehend what is going on there. Detailed of wiring is not my strong suit. If you or anyone wanna make some extra cash by making me a chart of which are what for both harneses.. I'll throw you some $$$
Old 01-29-2013, 12:13 PM   #7
ALLAN'S-S14
ALLAN'S-S14's Avatar
ALLAN'S-S14 is an unknown quantity at this point
To fix the constantly running wipers you have to use the jdm s14 silvia wiper amp; the usdm one does not work. I had the same problem with mine when I converted my s14 to rhd. Also have you figured out the wiring for the rear yet that's what i'm still working on?
ALLAN'S-S14 is offline   Reply With Quote
Old 01-29-2013, 12:39 PM   #8
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
Feedback Score: 26 reviews
hey man if i have time this weekend ill go through the fsm's for you. iv just been swamped at school :/ and i just did my rhd swap with a ka and for your wiper motor it sounds likeyou didnt switch any pins am i correct? if so that is deffinatly your problem because almost every usdm and jdm connector iv come across are just the mirror image of the other so there switched.
hope you solve this soon if not ill try and get to it this weekend
gl
-Mike
s14boy is offline   Reply With Quote
Old 01-29-2013, 04:22 PM   #9
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
http://zilvia.net/f/members/gsxrjjordan.html
Old 01-29-2013, 07:00 PM   #10
EnemyS15
Lol guys. You brought back a thread that is two years old. I have taken care of this problem since 2011 lol. Ty anyways
