Old 02-04-2013, 10:09 PM   #1
kcook737
kcook737 is an unknown quantity at this point
s13 S13 headlight not getting 12 volts?!?!
Hey guys, I just wanted to see if anyone was having any similar type problems. I just bought my 91 240 coupe a week ago. It's got it's issues but it runs and I love it. A main issue I'm having is driving at night. Only one headlight works. Only The drivers side low beam works and if I switch to high beams the passenger side only works. I started off by replacing the bulb but nothing changed. I checked the fuses and none were blown so then I started digging deeper. I hooked up a multimeter and checked the voltage in my headlights. The drivers side low beam has 12 volts where as the passenger side is only receiving 10. If I switch on the high beams its the exact opposite. Passenger high gets 12 volts and driver high gets 10. At this point I'm lost. Why would it get some power but not enough to get the bulb on. I haven't gotten deeper in yet and chased the wires but I really don't want to unless I have to. And I don't want to pay $80usd for a new headlight switch. Any ideas? Thanks in advance!
kcook737 is offline   Reply With Quote
Old 02-04-2013, 10:12 PM   #2
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
terminal might need cleaning
Old 02-04-2013, 10:15 PM   #3
kcook737
Any tips on doing so? High grit sand paper? And chemicals? Etc
Old 02-05-2013, 01:30 AM   #4
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Sounds like your selector switch on your column went bad. Had this exact issue same lights doing the same thing and switching the whole blinker switch assembly out fixed the issue. If you can't find one from a S13 some of the Nissan Hardbody trucks work as well.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 02-06-2013, 12:36 AM   #5
TheHustleHouse
TheHustleHouse's Avatar
TheHustleHouse is making a name for him/her selfTheHustleHouse is making a name for him/her self
Send a message via AIM to TheHustleHouse
had same issue. my problem was a combination of bad wiring and a bad headlight switch.
check your wiring, then do this
S13 Headlight Switch Repair : 240sx General Discussion
^^ that fixes all kinds of weird headlight issues.
TheHustleHouse is offline   Reply With Quote
