Old 02-07-2013, 08:20 PM   #1
ssigma6
ssigma6 is an unknown quantity at this point
300zx brakes on s13
So far I have front and back calipers, 300zx master, rear and front lines. My questions are:
Do I need the rear backing plate and shoe set up? (I am running an inline hydro)
If I use just my front 300 calipers should I swap the master or leave the s13 one in?
If I don't need the 300zx backing plates I will probably just install all the calipers with new shoes and rotors. I am just unsure as to what is truly needed.
Thanks guys!
ssigma6 is offline   Reply With Quote
Old 02-07-2013, 08:25 PM   #2
Edwin562
Edwin562's Avatar
all you need is here.
please search before starting a new thread. thanks
The Definitive 300ZX Brake Swap Paqe
Old 02-07-2013, 08:33 PM   #3
ssigma6
I have read that and found it really helpful, but is the backing plate necessary or can I just use the rotors and calipers in the rear?
Old 02-07-2013, 08:34 PM   #4
ssigma6
There is no need for a stock e brake if I am already using a hydro.
Old 02-07-2013, 08:34 PM   #5
Wabash9000
Wabash9000 has a little shameless behavior in the past
if you are not using the 300zx ebrake then you don't need the plate.
Wabash9000 is offline   Reply With Quote
Old 02-07-2013, 08:35 PM   #6
ssigma6
Thank you. This will save me a headache from sitting there installing the whole ebrake set up.
Old 02-08-2013, 12:19 AM   #7
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
If you have a way to keep the hydro ebrake on when parked you won't need it, just don't forget hydro's don't stay on without modification.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 02-08-2013, 11:02 AM   #8
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
also, a hydro is NOT recommended to be used as a parking brake
it is possible that the seals on either the master cylinder, or the caliper itself, will become fatigued from extended use of constant pressure.
personally i have never seen this actually happen, but it is another thing to consider.
i would recommend parking the vehicle in gear.
Old 02-08-2013, 01:45 PM   #9
zerodameaon
Huh did not even think of that, best advice is to carry wheel chocks as well because parking in gear is not safe on a hill unless you have other things to stop the car as well. If you have all the parts just put in the ebrake and be done with worrying.
