Old 02-08-2013, 05:31 PM   #1
tacostand
tacostand is an unknown quantity at this point
s13 z32 diff in s13 question
Well ive been searching for a couple of days in other threads about vlsd options for an s13 but i couldnt find a direct answer if i install the z32 diff if i will have to change the drive shaft? i know for the j30 you have to , but i went z32 as it has the same ratio as the s13 diff , i have the 5 bolt axles from the j30 just need to know if i have to change the driveshaft for the z32 diff
tacostand is offline   Reply With Quote
Old 02-12-2013, 05:53 AM   #2
jaxshawn
jaxshawn is an unknown quantity at this point
you can keep your stock drive shaft.
I have a n/a z32 diff in my s13 you just need the longer bolts for the front of the diff and everything bolts right up
jaxshawn is offline   Reply With Quote
Old 02-12-2013, 06:03 AM   #3
Croustibat
Why would you put a Z32 diff on an S13 ? OEM VLSDs have a limited life and cannot be serviced. The chances for anyone to find a working Z32 VLSD (working as in "being able to lock more than 3 or 4 corners") is quite thin. Unless you have a serviceable item ?
Old 02-12-2013, 06:38 AM   #4
jaxshawn
bc welded is horrible for DD and a legit LSD gear set is to expensive
Old 02-12-2013, 09:55 AM   #5
Croustibat
Err ... yeah well there is a reason for that: it is expensive to make, and only a few people buys them.
I dont see the point in installing a busted VLSD from a different model. The op may as well install an S13 opendiff, it will be easier to find, cheaper and will do the same as a busted VLSD.
If the OP does not want to drift, then an S15 HLSD is the cheapest LSD i know, and one of the most gentle on the drivetrain. I got mine complete in the pumpkin for 350€ shipped.
Old 02-12-2013, 08:00 PM   #6
007jones007
007jones007 is an unknown quantity at this point
^ maybe a 1000 dollar diff isnt priority to many other 1000 dollars worth of stuff that needs replaced on a 20+ year old car.
007jones007 is offline   Reply With Quote
Old 02-13-2013, 02:21 AM   #7
Croustibat
Hence the 350€ S15 HLSD, or the odd 100$ S13 open diff that will perform the same as worn out Z32 VLSD.
Old 02-13-2013, 12:12 PM   #8
Mikester
Mikester's Avatar
No you don't.
As far as prioritizing expenditures, good things cost money. Cheap out, and one will very likely get exactly what he/she paid for
