Old 02-19-2013, 08:20 PM   #1
milo2191
milo2191 is an unknown quantity at this point
RB Rebuilt and tuned RB20 full turn key swap
Rebuilt RB20 with ARP head studs and Cometic H.G new bearings (A full rebuild)
Same side Fmic with a real Turbo XS RFL (if you know this car you know how loud it is ha)
Oil cooler
FMIC Aluminum ducting
550cc inj
T28 off a rb25det (S1)
Boost is at 13.8lbs
Last tune was by lethal injection making 258hp 250tq with a glitchy TPS and MAF
r32 gtst power steering reservoir, custom power steering high pressure line works great
new rb26 coilpacks and harness
ngk plugs 4644s
Koyo Rad
Dual E-fans that are relayed to come on with key turned forward
Custom painted valve covers
removed the pan welded a ka24 oil drain portion on to the rb oil pan and then welded a 1/4 steel plate on the bottom (its bullet proof and been running great for the past few weeks.
Act stage 3 clutch works great
Upgraded z32 master aswell
custom heat shield
Custom 3 1/2 exhaust from test pipe area back sounds awesome
3000 obo thats with evrything drive shaft, fmic, rad, fans, koyo rad, gauges, and safc neo
text me im no good with checking messages on here 404-805-3774
milo2191 is offline   Reply With Quote
rb20det
