Old 02-28-2013, 01:50 PM   #1
Lazy706
Lazy706 is an unknown quantity at this point
Need help won't rev past 4-4500
Ok here's my problem car runs fine when it's cold revs up all the way up, but when it reaches operating temp it wnt rev past 4-4500 and gets worse the longer it runs. After a while it doesn't even want to start what could be wrong?
Lazy706 is offline   Reply With Quote
Old 02-28-2013, 02:03 PM   #2
Lazy706
Check ecu no codes, checked tps, checked the cps all tested good. Tried swapping maf made no difference.
Old 02-28-2013, 02:11 PM   #3
traxx07
Trader Rating: (63)
traxx07 is an unknown quantity at this point
Feedback Score: 63 reviews
MAF wiring? Maybe unplug maf and see if it does the same thing. (Warms up and doesnt rev past 4500 with maf unplugged.)
Maybe a sticking injector? Do all the basics. Check plugs, injectors, make sure your getting spark, grounds, etc.
traxx07 is offline   Reply With Quote
Old 02-28-2013, 03:34 PM   #4
Lazy706
Yup tried that still same problem. Imma have to try changing plugs n cables but I am getting spark. Any other ideas on wat I shud check?
Old 02-28-2013, 04:34 PM   #5
Lazy706
Question is it possible that my fuel pump is going out and gets weaker the longer I run? I know usually it works or it doesn't but i just want to kno if it's possible?
Old 02-28-2013, 05:11 PM   #6
s13panic
s13panic's Avatar
s13panic is an unknown quantity at this point
Maybe coolant temp sensor? If its getting an inaccurate reading when hot it can possibly either lean out or richen the a/f mixture. Can also cause no start condition when engines hot.
CLUSTER BOMB EC DORIFTO
s13panic is offline   Reply With Quote
Old 02-28-2013, 06:31 PM   #7
Lazy706
Yea I thought that too so I bought a new coolant sensor and swapped it still had the same problem.
Old 02-28-2013, 06:51 PM   #8
s13panic
s13panic's Avatar
What year and engine is it? KA has 2. One tells gauge what its reading and the other tells ecu what to do.
Old 02-28-2013, 07:26 PM   #9
Lazy706
93 and yea I changed the ecu one with 2 pins I believe thats the right one?
Old 02-28-2013, 07:32 PM   #10
Lazy706
Srry yea it's ka
Old 02-28-2013, 08:13 PM   #11
s13panic
s13panic's Avatar
Yea thats the ecu one. Gotta be something else.
Old 02-28-2013, 08:20 PM   #12
2.5T_/<ouki
2.5T_/<ouki's Avatar
2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice
Was exactly my problem when i did my swap. I was experiencing exactly what you are and once i swapped out my fuel pump all hell was unleashed and my baby boosted like no other.
2.5T_/<ouki is offline   Reply With Quote
Old 02-28-2013, 09:09 PM   #13
Lazy706
Alright I'll try that nxt I got a pump I can put in at home. I'll let uall know if it changes anything.
Old 02-28-2013, 09:34 PM   #14
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
hey hey hey i think that one happened to me before so luck i found ground wire connect firewall between rear cylinder head was loose bolt then tight bolt also make sure check all ground harness.
PIN GIO 2 is offline   Reply With Quote
Old 02-28-2013, 11:45 PM   #15
Lazy706
Thnx I'll try that also
Old 03-01-2013, 05:01 PM   #16
Lazy706
Well I swapped fuel pump no difference :/. And I tried looking for that ground wire but couldn't find it maybe because it's a de swap?
Old 03-02-2013, 07:47 AM   #17
Lazy706
Swapped out distributor and o2 sensor and so far problem has fixed. Not sure which 1 was my problem but Thanx for yalls help.
