Old 02-28-2013, 06:14 PM   #1
95zenkitoy
95zenkitoy is an unknown quantity at this point
My 95 240sx Fun project...
A few people might know of this car. It was built by a previous person i am just making it better and making changes to it.
When i got the car it had a shit load of vac leaks, a big ass oil leak, a SHITTT LOAD of dynamat (43lbs of it) ......Ive just been slowly changing things and working on making the car better, Ive found all of the Vac leaks and capped off alot of stuff that should have been. The car is now running a full 20psi and gets there instantly!!
Heres the build sheet--
S13 Redtop SR20det
CP 86.5mm / 8.5:1 compression pistons
Eagle H beam rods
Factory nissan main bearings and rod bearings and thrust bearings
Bottom end assembly balanced (westside performance)
Crank polished (westside performance)
Block decked (westside performance)
Head decked (westside performance)
New oem oil pump/timing chain cover
New oem timing chain assembly
New oem oil strainer/pickup
New s14 sr water pump
Nismo thermostat
Circuit sports water pump and powersteering pulleys
ATI crank pulley damper
New drive belts
Mishimoto radiator and fans
JWT S4 cams
BC +1mm intake/exhaust valves
BC spring and retainers
New oem valve guides
Supertech valve stem seals
New oem rocker arms
New oem rocker arm guide and shims
P2M RAS
New alternator
New oem front main seal
New oem rear main seal
New valve cover gasket
Cosworth head gasket
ISIS intake manifold
Aeromotive fuel pressure regulator
Walbro 255 fuel pump
engine harness wire tuck
Garrett GT3071R 63 a/r turbine w/ 3" v-band
Turbonetics evolution wastegate
turbo blanket
Treadstone topmount cast stainless steel log manifold
2.5'' downpipe to 3'' full exhaust with apexi turbo N1 muffler
braided SS oil and coolant lines w/ JIC fittings.
AEM wideband
Defi boost gauge
Nismo 740cc injectors
When i first got the car......
Then after 7hrs of detailing with all kinds of stuff and a toothbrush, i finally got the engine bay looking new again
Thennnnnn, Well then shit got a little crazy and i wanted to stand out but yet look good still. So i chose a whacky color to go with... And here is where shes at today!
Then i repainted the bumper because it had all kinds of rock chips and the paint was just peeling off like crazy everywhere
ANd Finally for now.....Here is a video of what the sr20 does with a nice beefy GT3071R at 20psi. Of course there are a shit load more mod's, so dont be that guy asking. Lol
240sx GT3071R sr20 - YouTube
95zenkitoy is offline   Reply With Quote
Old 03-01-2013, 10:08 AM   #2
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
Please colormatch your hood. Other than that, looks like a nice foundation to build from. Engines certainly ready to rumble.
simmode1 is offline   Reply With Quote
