Old 03-12-2013, 06:51 PM   #1
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Alpha-N tuning
Hello friends,
Can anyone point me to some good resources on doing an Alpha-N tune for an ITB setup?
Is anyone on here running such a tune?
What sort of management can be used?
I will most likely be using Nismotronic, which seems like the best deal so far.
Thank you for any information.
Old 03-13-2013, 03:27 AM   #2
Croustibat
Stupid question but ... why would you use an alphaN setup ? It sucks, to put it plainly.
Old 03-13-2013, 07:51 AM   #3
zurud
zurud is an unknown quantity at this point
sr20det don't use alpha N unless you go stand alone.
zurud is offline   Reply With Quote
Old 03-13-2013, 09:59 PM   #4
JKTUNING
JKTUNING's Avatar
JKTUNING is an unknown quantity at this point
I believe he will be using an ITB setup, which is much more easily tuned with alpha N or an alpha N and map hybrid system.
NismoTronic SA has the capability to run alpha N or a hybrid alpha N and speed density for fueling and ignition scales.
You can achieve this by setting the SET1 maps to Speed Density (map sensor) and setting the SET2 maps to alpha N (TPS only), then you can switch to the SET 2 maps in the software when you are over a certain MAP load value.
This requires a decent vacuum block and vacuum source from each runner and the map sensor is usually mounted right to the vacuum block to help dial in idle and part throttle drivability.
NismoTronicSA Tuning Package
Dyno Tuning and ECU Services
Mustang AWD-150 | DynaPack 3000
JKTUNING is offline   Reply With Quote
