Old 03-17-2013, 08:38 PM   #61
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
your car will start a tooth off on the cas just take some work lol, but when we say came timing we are talking about intake cam to exhaust cam to crank timing
idahotuner is offline   Reply With Quote
Old 01-29-2014, 01:43 AM   #62
tom_sr20
tom_sr20 is an unknown quantity at this point
condition of ignition coils
if timing is good. how are your ignition coils? mine had this same stumbling problem for years that ive owed my sr. fixed when i changed out all four ignition coils. might want to check yours for cracks. mine didnt have any cracks but since i was willing to take the chance of fixin the problem i bought four new oem coils. it does have 100k plus miles on them too so i think it was about time. fixed my problem made it feel stronger as well. hope this helps
tom_sr20 is offline   Reply With Quote
Old 11-20-2017, 12:05 PM   #63
Jrc36
Jrc36 is an unknown quantity at this point
s14 Bugging out after 4k rpms
What's going on I have the same problem on my S14 Notch Top , after 4k rpms it bugs out when I try go give it more gass , I was told that it's the Maf , can that be true if i have the wrong Maf ?
Jrc36 is offline   Reply With Quote
Old 11-20-2017, 12:25 PM   #64
koukimonst3r
koukimonst3r's Avatar
koukimonst3r is an unknown quantity at this point
Do you know which one you have?
52F00 is S14 Zenki SR20DE
52F01 is S14 Kouki SR20DE
69F00 is S14 Zenki SR20DET
69F01 is S14 Kouki SR20DET / S15 SR20DET
ig : koukimonst3r
koukimonst3r is offline   Reply With Quote
Old 11-20-2017, 01:32 PM   #65
Jrc36
I have a 69F01 AFH50 - 18A
Old 07-14-2018, 05:05 PM   #66
Abeo
Abeo is an unknown quantity at this point
Bump from the dead. I had this problem for the longest time, and this was one of the threads that kept coming up when I searched.
My car was slow to spoil, had weird timing retarding in boost, and had sluggish throttle response even at idle. Turns out it was the PCV valve making a huge boost leak that was being dumped into the intake pipe after the maf across the valve cover. Since the air was metered, it didn't show the typical symptoms. The PCV rattled and I couldn't blow through it ... Blocking it off while testing something else identified it.
Just wanted to add my solution after chasing this problem for a long while.
Edit: Turned out my car had a bad CAS also. Had timing scatter that was really bad after 4500 rpm, identified by a timing light while revving it up (it would jump from ~15 degrees to ~40 for an instant). The car was on the dyno and had a up and down torque curve showing the engine knocking, going on the knock map, then off, then knocking again...
Abeo is offline   Reply With Quote
Old 08-16-2020, 11:33 PM   #67
Tulok
Tulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really nice
I had similar symptoms chased them for months. Turns out that the block and head had been shaved during rebuilds.
Solution was get adjustable cam gears and degree them so the intake began to open at about 8* btdc. Moved spool down at least 1500rpm. Would spin in 3rd where before it could barely boost in 1st. Open waste gate t25 on race gas
Tulok is offline   Reply With Quote
